4,138 -
Calendar
Everything posted by ante
audioguru, I still think the Darlington is the better choice. We are talking about pulses that are of different length (PWM) and between the pulses the transistor
I need a datasheet and/or application note for Philips ZP 1311 G/M detector, it's an old one I know. Thanks! Ante
ginji, What is the application? Ante
audioguru, You stated,
audioguru vainajala, The collector outputs in the 494 can sink 200mA maximum, will this suffice as base current for three transistors? What makes you think that a Darlington can
Vainajala audioguru, I think it
Help please, Need 12 V DC Power Supply for ATX Mainboard
ante replied to acgozali's topic in Electronic Projects Design/Ideas
Andy, The ATX main board or motherboard uses several different voltages one of these is +12Volts. Your computer won -
vainajala, Try to use a 2.2k for R3. As far as I can see the emitters and collectors of the TL 494 is correctly connected. With the change of R3 the efficiency should improve a bit and the heat in R2 will be reduced. Have you access to a scope? I would be useful to see how Q1 performs and possibly make some minor changes to improve the efficiency. Ante ::)
Mixos, This is mounting to quite a library! Good Work! Ante ::)
vainajala, Looks very nice, please keep us posted! ;D Ante ::)
Laet, I suggest that you connect the rely on the other side of the transistor to start with. Ante ::)
Laet, First, are you sure the coil resistance is 6.7 Ohms? This will be one HOT relay, nearly 30W it seems too much ???. Now that we know the purpose of the relay it
shekhar, What I mean is the length and the diameter of a cell. Ante ::)
Kain, Everybody makes mistakes sometimes, don
audioguru, I
Kain, With no external divider the 3V battery will show
Han, This is the easiest way I can think of, but maybe you had something different in mind? Ante ::)
Kain, Yes it
HAN, What kind of battery do you have 12V or 6V and what
Kain, There is one more thing to consider, these meters can usually not be powered from the same supply as you measure on. This is not a big problem, there are several ways to fix this. Ante ::)
HANIFF, Welcome to the community. I need to know some more details. What is the
audioguru, So that
Kain, Try to find the datasheet from your suppliers panel meters and study it. Most of the LCD & LED panel Volt meters have 199,9 mV, 1,999 V, 19,99 V, 199,9 V ranges. On the 199,9 mV range just shunt with a 0.01 Ohm resistor and your meter will show 0
