4,138 -
Posts posted by ante
audioguru,
I still think the Darlington is the better choice. We are talking about pulses that are of different length (PWM) and between the pulses the transistor -
I need a datasheet and/or application note for Philips ZP 1311 G/M detector, it's an old one I know.
Thanks!
Ante -
ginji,
What is the application?
Ante -
audioguru,
You stated, -
audioguru vainajala,
The collector outputs in the 494 can sink 200mA maximum, will this suffice as base current for three transistors? What makes you think that a Darlington can -
Vainajala audioguru,
I think it -
Andy,
The ATX main board or motherboard uses several different voltages one of these is +12Volts. Your computer won -
vainajala,
Try to use a 2.2k for R3. As far as I can see the emitters and collectors of the TL 494 is correctly connected. With the change of R3 the efficiency should improve a bit and the heat in R2 will be reduced. Have you access to a scope? I would be useful to see how Q1 performs and possibly make some minor changes to improve the efficiency.
Ante ::) -
Mixos,
This is mounting to quite a library!
Good Work!
Ante ::) -
vainajala,
Looks very nice, please keep us posted! ;D
Ante ::) -
Laet,
I suggest that you connect the rely on the other side of the transistor to start with.
Ante ::) -
Laet,
First, are you sure the coil resistance is 6.7 Ohms? This will be one HOT relay, nearly 30W it seems too much ???.
Now that we know the purpose of the relay it -
Kain,
Everybody makes mistakes sometimes, don -
audioguru,
I -
Kain,
With no external divider the 3V battery will show -
Kain,
Yes it -
HAN,
What kind of battery do you have 12V or 6V and what -
Kain,
There is one more thing to consider, these meters can usually not be powered from the same supply as you measure on. This is not a big problem, there are several ways to fix this.
Ante ::) -
HANIFF,
Welcome to the community.
I need to know some more details. What is the -
audioguru,
So that
darlington optocoupler
in Datasheet/Parts requests
Posted
Ginji,
Are you sure it is broken? This is a component that does not break down under normal conditions.
Ante
