4,138 -
Posts posted by ante
MD,
http://www.mospec.com.tw/pdf/power/2N3441.pdf
Ante ::) -
yourwinns,
The BFR90 can be replaced with BFG90, BFQ28, BFR14, BFR49.
The MC3403 with LM324
And the NTE112 is a TV UHF Mixer diode can be replaced with BA481
Ante ::) -
Rhonn,
That was strange, can -
Bob,
I have replaced your R2 with two resistors. The op-amp will (I hope) put out approx 3Volts when 6 A is passing through the -
audioguru,
Why not! And it -
MP,
Just click on -
Audioguru,
As surveillance for a plant (dumb or not) it sounds like very good circuit. I have to agree on your thoughts about the form of message the first circuit gave. Your suggestion will of curse give a much clearer message. Even JLB:s application measuring salt concentration can perhaps benefit from the new circuit.
I say: fine by me!
Ante ::) -
Rhonn,
You have to be a member to download, just register and you are!
I am.
Ante ::) -
Bob,
What is the highest value possible for R2? This will determine if the opto LED can be driven right off the voltagedrop or else you need an op-amp to boost the voltage.
Ante ::) -
Hi Guys,
Here are some nice projects on this site, among others something for the LM35.
http://www.x-robotics.com/sensores.htm#LM35
I hope it will generate some ideas!
Ante ::) -
Thanks MP,
I was not sure about it.
I hope it can help James.
Ante ::) -
Bob,
I guess we where writing simultaneously as I saw you message after I was finished with mine. Is it only motion you want to detect? In that case an opto sensor will come in handy, giving an output while the shaft moves and non when it stops.
Ante ::) -
To clarify things can someone please make a drawing for all to look at as reference? ???
Ante ::) -
James & audioguru,
I my have misunderstood, -
Bob,
If the stall current is 1A, under which circumstances do you expect 6A?
Ante ::) -
From the original circuit remain one resistor, one potentiometer two caps and a LED. I would call that a change.
Where is the finished circuit then? I sure there are some readers that are a bit confused not getting to see the hole picture (drawing).
Ante ::) -
Yes all of them can be replaced. As long as they are equivalent in data.
Ante ::) -
audioguru,
Well then, this is where you come in to the picture. From scratch, design and post a circuit suitable for this job. Then it -
James,
There are many ways to do this. If it -
Kasamiko,
I,m sorry I don
Lead-Acid Battery charger
Posted
Hi Rhonn,
Do you want to build or by one?
Ante ::)
