4,138 -
Posts posted by ante
I have deleted many posts to prevent the frustration when finding posts with a headline of interest just to find “deleted by admin inside”!!! ??? ??? ???
I can’t see any reason to have a moderator for this board any more, just delete all of it and there are no problems!
Over and out! -
I don’t know if this will help but the “Where am I sensor and methods for mobile robot positioning” will be posted in Resources! ;)
Hi John,
You are right John the notes should be read first, this is not for beginners.
However the schematic I posted is the updated and corrected version according to the author.
I also found the datasheet but no source where this IC could be bought! Did you find any source for it John? -
If the amp was rated 1400 real “whats” the input current would be almost 200A @ 12VDC! :o
The conversion from 230VAC to 12VDC and up again to something like 2 X 60VDC would be ineffective and a wasteful. A 500VA transformer will do the job with plenty of headroom. You will have to (as SM2GXN suggested) find out the voltage inside though. And also a picture and if possible a schematic would be nice! ;D -
Hi frank,
If I where to power a car amp for indoor use I would find out how its internal power is arranged first. I don’t know about the one you’ve got but I seen a few and most of them has a 12 VDC to +- 35 – 70 VDC converter inside. What I would do here is tap in between the converter and the amp with my own PSU. This will allow me to use a cheaper transformer and avoid the high currents. -
Dear M. Rajesh,
Thank you for your kind words. I believe in shearing information and knowledge among everyone that has an interest. I also believe that every person rich or poor should have access to this kind of information for free. We will all gain from this! ;) -
Hi ElectronicsGeek,
Of curse you can shorten the charging time by increasing the current! But by doing so you might also shorten the life of the battery considerably! If you care for the battery and want to avoid damage you should stick to the manufacturers recommendations. -
I found another one today:
;D
[attachment deleted by admin] -
I guess this is much like how most power windows are configured. You could try some Honda club or forum for the schematic.
Hi Kevin,
Welcome to our forum.
Is this the same as Crocodile Technology?
In that case the version was 6.05 the last time I saw it. -
AG,
Can you see the circuit now? ;D -
Mixos,
I am sorry if I upset you but I too tried to keep thing on a respectable level. I see now that I should not got in between and put my nose in this stupid battle like I did! Won’t happen again since I trust you will take care of it in good time as soon as it starts again! -
Hi dale,
Perhaps something like this might help you? -
You need the Visual Basic run dll file to run this software.
Can be downloaded from Microsoft and many other places. -
Yes all i would have to do is tap into the wire that goes to the driver side door. if i was going to wire all of them in parallel, how exactly could I add a timer or some sort of other thing so they all roll down with just one press of a button and not holding of the switch untill they are down. -
Hi Jack,
Ok, I’ll add a PLC thread in “Resources”!
Coming up shortly! 8) -
If all the windows latch to down position on a short impulse it should be easy. Just wire them all together from one switch using a diode in series for each window and the standard wiring won’t be affected!
Hi kebloks,
Yes, that’s about it. But, it also depends on the circuit where you are going to replace the transistors. -
"I will go with your suggestion, mixos...and I will ignore the crap from ante.
MP"
Have someone deleted the post containing the message on which this statement is based?
Mixos, I on the other hand expect some answers from you! -
Hi Jack,
I have a few books on the subject, how deep do you want to go into PLC’s?
Shall I post them all here? ;D -
mp,
You are obviously too good for the rest of us then! And, as usually the lack of self confidence appears in the way you answering a post! By only answering selected fractions of a post you avoid the things where you have no clue or have run in to a dead end! This is a sign of weakness and you are making a foul of yourself! There are numerous examples of this behavior in your posts! I did not advise against posting in any threads, just to quit while you are ahead! You should read your own posts!! -
MP,
I don’t think you should continue stalking Audioguru! In almost every thread he appears you immediately try to find something to argue about even if you have to split hairs you can’t stop yourself from interfering. I am all for discussions but this is not the proper way to discuss electronics or any other matter! We have an obligation to the members to deal with this in a proper way and not let this go out of hand. As I suggested earlier; ignoring might be the best medicine!
I have gotten plenty of mails and PM’s from concerned members about our disputes! I hope that none of the youngsters see the behavior here as a model, god forbid!
Would this work on a motorcycle?
in Projects Q/A
Posted
It will probably not work in any vehicle as is considering the note:
