4,138 -
Posts posted by ante
Hello Gary,
Welcome to our forum!
Thanks for your generous offer!
Is there any webpage for us all to browse through to see what you do? ;) -
Sorry, haven seen any ready made in black.
Hi tubbytwo,
Just curious, is this a replacement for an old 90V anode battery? -
Should be fine for the job!
Yeah, someone got it fixed perhaps they have paid the bill now! ;D
Interesting replacement for the 78XX but unfortunately too clumsy for what I had in mind though! -
Hi ben,
You can post a picture and we will try to figure out what it is! -
Ok, that might work too! ;D
Why not use a can of black spray paint?
The LM7805 has its tab connected to ground so cooling it can be done by bolting it to the car chassis as it then also will be connected to negative.
(Not applicable on some older British cars though!) ;D -
Hi AG,
Why not run them through the scanner and post them here?
At least some highlights would be nice! ;) -
I like your desktop Herman! ;D
I think “Trace thickness” should be set to “Mills” first, try it! ;) -
Hi Shahriar,
I don’t know what a new ATX PSU costs in your part of the world but where I live they are very cheap, almost no one repair them and in doing so jeopardizeing the life of the computer.
As you put it “Sometimes, Shit Happens!” ! ;D
Perhaps you are doing this for educational purposes? ;) -
Hi vinodkp,
Welcome to our forum.
I am sorry to hear about these problems, the first thing that comes into my mind is your software. Since you are using winace and I have no experience with this software I would recommend trying your files with WinRar which is the software used to compress these files. When using WinRar, remember that all the parts must be in the same folder when unpacking.
Good luck and please let us know how it develops! -
The current limit circuit will work with almost any NPN transistor.
Hi Guys,
OT but way back we called TV-sets containing tubs and transistors hybrids! ;) -
You can start by dismantling the Walkman so you can see what parts you have to play with! Then you come up with an idea and we’ll see. ;)
Yes, that was number two. Just so that you know; I am all for religion as long as it’s the peaceful and loving kind! So you have the avatars turned off, maybe you don’t like Logan’s avatar either? If you don’t know what pictures anyone uses how come you know that you don’t want to look at them?
I am not going to try to pull anything more out of you and since you as usual only answers or give your opinion on half of what I say I don’t have the energy to comment any further or trying to be constructive about the main problem.
I leave this here for Mixos to take care of!
Thank you! -
Some inductive loads can overheat when using square wave.
Hi catsfly,
You probably have to custom build a controller circuit for your motor. We need to know the motor data, the voltage from your outlet and perhaps a few things more to be able to help out. -
That’s correct John, almost never ;)
Yes, projects Q & A should be for members and especially newbie’s who are building the projects. In line with helping these builders it’s sometimes (for some of the projects) hard to refrain from warnings. I think one way of helping is when you can actually advice how to spend your money in a better way by choosing different parts or connect the pieces together a little differently and so on. This is what I call good advice and it should be allowed in projects Q & A. If not the projects presented on this site should be decontaminated so that no newbie’s will fall in a hole unnecessarily.
I do not agree when you say that AG is driving people away, on the contrary I read many posts where they thank him for his help and inputs. As I am sure you have noticed that I too have disagreements with AG from time to time but not at the same level as you two have by far. In some cases I have taken your side in arguments with AG because I believed you to be correct. This time it’s more than technical issues and I think you have gone too far.
Rubbed me the wrong way?, no worries I am ruff stuff. I also believe in letting the steam out and cards on the table for a cleaner environment! ;)
I did not see any response on the problem number two issue.
PLC and Power Electronics Forums
in Feedback/Comments
Posted
Hi guys,
I believe a PLC board would be nice, but I don’t think it should be mixed with the microcontroller board since they are very different in terms of use.
Also a power electronics board could have a great potential!
Aaron, I suggest you PM admin (Mixos) about your thoughts! ;)
