4,138 -
Posts posted by ante
Well, IGBTs are a kind of power transistors (Google IGBT) and you have to have some basic knowledge to be able to test them properly. You will find them on the heatsinks (if the manufacturer use this kind of transistors) they come in many shapes so I don’t know exactly what they looks like in your inverter, some are even light trigged by optofibres. A schematic and a service manual would be nice too! Have you made a visual inspection of all the parts, looked for burns or discolored parts or pcb sections?
So MP, you have that kind of background too, mine where backstage! As a tech-manager for some rock musicians in the early seventies to the beginning of the eighties I have seen plenty of equipment. Speakers, amplifiers, echo’s and plenty of other stuff from Marshall, Laney, Dynacord, Hagstrom, JBL, Vox, and some names I forgot. And sure, they all had series connected speakers and paralleled speakers and all of them worked fine even the once equipped with my homebrewed crossovers! ;D
Hi jryan,
Welcome to our forum.
The Martel calibrator looks expensive; you are obviously looking for a simpler solution. I had a similar question not long ago here: http://www.electronics-lab.com/forum/index.php?topic=8260.0
This might be a start. ;) -
Impossible to answer! Too many factors like percentage of area to be etched away, the type of pcb foil (20, 35, 70u), the solution you use, temperature and more.
Hi alkv,
I don’t recognize the model of your TIG, I guess it’s not a US or EU made one?
The fact that it shuts down just after power up suggests that it performs a self test which fails. If the fan has been broken the odds are that something has died from overheating, have you checked the IGBTs for short or open circuit? -
Does this sound level indicator have an echo too? ;D
Hi monoman,
A circuit which converts DC to AC is usually called an inverter are you sure this is what the circuit does? Can you post the schematic so we can see what you have built? -
Hi boschman,
Why did you remove it form your cars instrument cluster? Do you suspect there is something wrong with it? What are the symptoms?
I do not recommend replacing it with a jumper, this can turn out to be a very expensive test!
I still believe it is a capacitor, have you measured it? -
Is this the same persons leaving the room as in the “Light management system” thread?
OK, you could use AC-fans and a simple triac control for the regulation.
Hi Zeppelin,
Not critical, just any DC works since it’s shopped up anyway at a high frequency. -
Hi ferris,
Are you sure you want to control the fans yourself?
Why not just let them run at a slow speed (silent) as soon as you use the equipment? -
Hi boschman,
Welcome to out forum.
This is most likely a capacitor 100nF (0.1uF) and it has nothing to do with horseracing! ;) -
Thanks AG,
I’ll brows through it!
Just a short comment at this stage;
This is a local UK manufacturer unknown to me. I am familiar with some of the stuff manufactured by for ex. Zapi, Sevcon, General Electric, Cable Form, Curtis, Linde and Sigma to name a few.
I did not expect to find any deep going presentation on how to construct a PWM circuit and this was immediately underlined, quote: “4QD manufacture PWM speed controllers for electric motors so you will hardly expect us to give you all our own unique circuitry and technical know-how” ;) -
Hi AG,
I couldn’t care less about the way a golf carts drive system is constructed! I know from experience how torque changes and how it’s possible to optimize it by changing the frequency of the PWM. There are even times when there is a substantial gain in changing the frequency within a certain range in proportion to the rpm to have maximum torque over a wider rpm range. But as far as I know only changing the pulse width is a proper way to control the rpm. -
I agree; using this kind of non galvanic isolated device is suicidal! :o
Hi AG,
If you like to improve the stability of the zener D8 it is possible to add a standard rectifier diode (i.e. 1N400X) in series (head on). -
I don’t know where you live but this came up (and many more) on “prism+laser” in Google!:
http://www.escoproducts.com/html/prisms.html -
Thanks Tkjas!
Have you tried it? Is it stable enough to get a reasonably good measurement? -
Hi thoffen,
You could fit a prism to the shaft of a stepper motor and aim the laser at it. This stepper could then be fixated to another steppers shaft and you got X, Y and Z.
Poor cat! ;D -
If that did not help; this might: http://www.electronics-lab.com/forum/index.php?topic=5379.126
;D -
I think I cooked my A/V Transmitter
in Service Manuals
Posted
Yeah, that was pretty stupid! ;D To pinpoint which parts can be expected to be dead we could use a schematic! If you are very lucky only a few parts are toast.
