4,138 -
Posts posted by ante
I don’t know anything about the content of the Heath books you’ve got. However the few Heath-kits I have built myself many years ago had some very pedagogical documentation.
If you are going for test equipment projects I can recommend this one: http://www.uoguelph.ca/~antoon/circ/latching.html
Very useful in many cases yet simple to assemble! -
Hi,
The STRF6552 is a voltage regulator (expensive type). A picture of the “transformer thing” would help identify it. We are waiting for the pics! ;) -
I’d like a slice of that lemon in my vodka please!
Oh, and some ice too! ;D -
Hi helluvawreck! (No offence) ;D
Welcome to our forum!
You seem to have your hands in almost everything and even wants some more! I know the feeling; it’s nice to be in control of everything if possible or at least try to find out how everything works and interconnects.
I would buy used test equipment to keep the prize at a reasonable level and maybe get a few extra accessories in the deal too.
Do you have any special requests for projects or just anything to start with? Have you checked out our projects here on E-Lab? ;) -
I guess it’s like comparing a gallon (inp. vs US) they are not even close!
Or a ton vs a tonne and a ton!
Or short ton = 907.2kg vs metric ton = 1000.0000000000000kg how stupid is that? ;D
I stay with metric like Europe; it’s much simpler this way! 8)
Or perhaps one day there is only 907mm on 1 meter!? ;D -
Hi Herman,
I do not have Eagle installed in my computer; you can (while Eagle displays the circuit) make a screen dump (Prnt Scrn key) and post it here. 8)
For the future (wouldn’t have helped in this case but); if you have a file with a suffix not allowed (like .sch) just ZIP or RAR it and it’s possible to post it. ;) -
You could use one of these, 6 or 8 A will do:
http://www.elfa.se/elfa-bin/setpage.pl?http://www.elfa.se/elfa-bin/dyndok.pl?lang=en&dok=2013541.htm
Hi Jim,
Your local electronics store might have a kit for you. Most simple timer kits use the 555 IC instead of the CD4060 which I prefer, but still it works as a timer. -
Hi Nick,
If you need hundreds of LED’s you might want to try one of these:
http://www.superbrightleds.com/
http://www.dotlight.de/shop/
http://www.besthongkong.com/
Have a Good one Mixos!
Hi NanOp,
I don -
I would call this unnecessary littering!
It all depends on the engine and what
Dear Ante
Would you mind just telling me the sensor output voltage in two condition (PWM=1 & PWM=0) if we assume the Distance between The sensor and Electromagnet is constant (just approximate numbers).
i.e If the distance is 2Cm the
Vout = ??? when PWM =1
Vout = ??? When PWM =0
That is impossible to answer, it depends on a lot of factors. -
Hi rod,
Accessing from the inside of what, the engine or the car? -
To power the timer a small PP-3 and a low drop regulator like L4940 or similar would be fine, this will keep the timer run exactly right each time.
Here are a few examples on CD4060 circuits, of which some are very well explained:
http://www.circuitsonline.net/circuits/view/106
http://www.doctronics.co.uk/gt_1.htm
http://uk.geocities.com/ronj_1217/al1/24t.html
http://www.hometoys.com/tips/tips18.htm
http://users.otenet.gr/~athsam/timer_with_buzzer_and_optocupler.htm
http://www.zen22142.zen.co.uk/Circuits/Timing/ivt.htm
http://www.ieee-rgit.com/viewproject.php?id=2&PHPSESSID=fab893c4e61ebfc9fec74a12f6fd5cba
Hi AG,
Yes I too have some doubts about this circuit. The size and the characteristics of the piezo will be important for the sensitivity. -
The project's output can be changed a little to drive a transistor that can turn on an alarm when there is an earthquake nearby, if you don't feel the vibrations yourself. It will probably also detect lightning's thunder pretty well. Maybe also kangaroos jumping along? Elephants? ;D
So we are talking a 7.0 or higher on the Richter scale here? ;)
Hi MP,
Thanks,
Herman: Not important what kind you use as long as you can post it here! -
Hi EDY,
I don -
Hi Mooncat,
Is it dead or does the discharge part still work? Do you have a schematic to post? Some pictures of the internals perhaps? Have you checked for fuses (might be soldered to the PCB)? Have you measured the temp switch inside the battery for open circuit? -
Certainly won
What is holding switch mode PSUs back?
in Theory articles
Posted
Hi Guys,
Today SMPSU’s are found frequently in home electronics equipment. Almost every VCR, DVD players, tuners, TV-sets and similar has got them and so do every computer laptop or other computer. The smaller and lighter SMPSU’s are cheap to make and they save weight and space in the containers shipped form Asia to US and Europe. The cabinets can be made smaller since the temperature rise and the need for cooling is less, and no bulky transformer. However I haven’t seen any in audio power amplifiers for home use yet. Audio power amplifiers for vehicles always got switchers for the step-up voltage converter. Most SMPSU’s run in the 30 – 200 kHz range and should not cause any hum in audio equipment, perhaps the high current demand in a power amp is the reason? But then again today’s computers carry PSU’s up to 700W and more at very high current levels so I’m not sure about that.
BTW, my lab-PSU (0-40V 0-5A) is a switcher too! ;D
