What is 12 volt 30 amp switching?
This switch is one of the most powerful switches with a voltage of 12 volts.
Voltage of 12 volts and current of 30 amps This part eliminates the need for any electrical device that needs 12 volts.
This piece is mostly used for cases where a lot of current is used!
Features of this switching
This converts 220 volts of ac city power to 12 volts dc.
And the maximum output current of this piece is 30 amps!
Now you ask yourself what will happen if you use the maximum power of this piece?
I must say that the 12-volt, 30-amp switch has a s
