2 -
Days Won
1
Blunt Viscardi last won the day on November 6 2023
Blunt Viscardi had the most liked content!
Recent Profile Visitors
Blunt Viscardi's Achievements
paulsi1ver started following Blunt Viscardi
Veswin reacted to a post in a topic: W25Q32JV FUNCTIONAL DESCRIPTIONS
W25Q32 refers to a specific model of serial flash memory produced by Winbond Electronics Corporation. In particular, the "W25Q32" is part of the W25Q series, which consists of a range of flash memory chips differing in capacity and features. Standard SPI Instructions: The W25Q32JV is accessed through an SPI-compatible bus consisting of four signals: Serial Clock (CLK), Chip Select (/CS), Serial Data Input (DI), and Serial Data Output (DO). Standard SPI instructions use the DI input pin to serially write instructions, addresses, or data to the device on the rising edge of CLK. The DO output pin reads data or status from the device on the falling edge of CLK. SPI bus operation Mode 0 (0,0) and 3 (1,1) are supported. The primary difference between Mode 0 and Mode 3 concerns the normal state of the CLK signal when the SPI bus master is on standby and data is not being transferred to the Serial Flash. For Mode 0, the CLK signal is typically low on the falling and rising edges of /CS. For Mode 3, the CLK signal is usually high on the falling and rising edges of /CS. Dual SPI Instructions: The W25Q32JV supports Dual SPI operation when using instructions such as "Fast Read Dual Output (3Bh)" and "Fast Read Dual I/O (BBh)". These instructions allow data to be transferred to or from the device at two to three times the rate of ordinary Serial Flash devices. The Dual SPI Read instructions are ideal for quickly downloading code to RAM upon power-up (code-shadowing) or for executing non-speed-critical code directly from the SPI bus (XIP). When using Dual SPI instructions, the DI and DO pins become bidirectional I/O pins: IO0 and IO1.
The MCP2200 from MICROCHIP manufacturer is a DDR with USB-to-UART 1-CH 64Byte FIFO 3.3V 20-Pin SSOP. More details for MCP2200 can be seen below. Details The MCP2200 is a USB-to-UART (Universal Asynchronous Receiver/Transmitter) bridge controller chip developed by Microchip Technology Inc. It enables seamless communication between a USB host (like a computer) and a UART-based microcontroller or other UART-enabled devices. The MCP2200 allows easy integration of USB connectivity into various embedded systems. Feature USB 2.0 Full-Speed (12 Mbps) device with on-chip transceiver. Integrated UART with baud rates from 75 bps to 1 Mbps. GPIO (General Purpose Input/Output) pins for additional functionality. Configurable I/O pins for various control and status purposes. Customizable USB descriptors to provide information about the device. Bus-powered from USB, eliminating the need for external power. I²C™ (Inter-Integrated Circuit) protocol support for serial communication with other ICs. Programmable EEPROM to store various configurations. Application USB-to-UART bridge for interfacing with UART-enabled devices. Serial communication interface for microcontrollers and other embedded systems. USB-based data acquisition and logging systems. Custom USB communication solutions for various applications. Virtual COM port (VCP) for communication with a computer.
