9 -
Contact Methods
Website URL
www.tecksay.com
Recent Profile Visitors
Aaron-Tecksay's Achievements
The TS-M1030D is a compact Bluetooth Low Energy (BLE) Bluetooth module, featuring a Bluetooth 5.0 chip and support for BLE4.2 and BLE+SPP dual-mode protocols. It also supports AT commands, allowing users to modify parameters such as serial port baud rate and device name. Additionally, the data control module’s I/O ports can be directly accessed via an app for flexible and straightforward operation. This module offers outstanding stability, ultra-low cost, minimal power consumption, and high receiving sensitivity. Model No.: TS-M1030D Features Bluetooth Version: BLE 4.2+SPP 3.0 Frequency Band: 2.402GHz-2.480GHz ISM band TX Power: -20dBm~+4dBm Receive Sensitivity: -97dBm Air Rate: 250Kbps/1Mbps/2Mbps Antenna: PCB Onboard Advise Range: 80m Memory: 160KB FLASH+20KB RAM Size: 17*13*1.5mm Pin/GPIO: 21/16 Power Supply: 1.8~3.6V Operating Temperature: -40℃~+85℃ Peripheral Interface: UART/SPI/I2C/ADC Serial Transparent Transmission Rate: BLE 4KB/s, SPP 16KB/s Applications Smart home Location tracking Intelligent educational equipment Measurement and monitoring system Industrial sensors and controls Medical equipment monitoring and wireless control
The TS-M1021 is a diminutive Bluetooth module, measuring merely 8 by 12 millimeters, designed for applications requiring minimal size and low power consumption, without compromising on cost-effectiveness. This module is renowned for its remarkable stability and wide-ranging compatibility. It comes with a default setting that facilitates Bluetooth serial port transparent transmission, allowing users to modify serial port baud rates, device names, and additional parameters using the supplied AT commands. This feature enables adaptable operation and straightforward implementation, making the module an ideal choice for a diverse array of customer development projects. Model No.: TS-M1021 Features Bluetooth Version: BLE 5.1 Frequency Band: 2.402GHz-2.480GHz ISM band TX Power: -20dBm~+10dBm Receive Sensitivity: -97dBm Air Rate: 250Kbps/1Mbps/2Mbps Antenna: Ceramic Antenna Advise Range: 100m Memory: 512KB FLASH+56KB RAM Size: 12*8*1.5mm Pin/GPIO: 12/7 Power Supply: 2.0~3.6V Operating Temperature: -40℃~+85℃ Peripheral Interface: UART/I2C/ADC Serial Transparent Transmission Rate: BLE 20KB/s Applications Smart home Location tracking Intelligent educational equipment Measurement and monitoring system Industrial sensors and controls Medical equipment monitoring and wireless control
TS-M1020D is an 8*12mm ultra-small size Bluetooth low power ultra-low cost Bluetooth module, the module is a Bluetooth 5.2 chip, integrated BLE+SPP dual Bluetooth protocol, with excellent stability and compatibility. Module default Bluetooth serial port transparent transmission, the user can change the serial port baud rate, device name and other parameters according to the provided AT instructions, flexible operation and simple use. Suitable for various development projects of customers. Model No.: TS-M1020D Features Bluetooth Version: BLE 4.2+SPP 3.0 Frequency Band: 2.402GHz-2.480GHz ISM band TX Power: -20dBm~+4dBm Receive Sensitivity: -95dBm Air Rate: 250Kbps/1Mbps/2Mbps Antenna: Ceramic Antenna Advise Range: 80m Memory: 256KB FLASH+128KB RAM Size: 12*8*1.5mm Pin/GPIO: 12/7 Power Supply: 3.1~4.35V Operating Temperature: -20℃~+85℃ Peripheral Interface: UART/SPI/I2C/ADC Serial Transparent Transmission Rate: BLE 4KB/s, SPP 16KB/s Applications Smart home Location tracking Intelligent educational equipment Measurement and monitoring system Industrial sensors and controls Medical equipment monitoring and wireless control
The TS-2103B Bluetooth Beacon is an ultra small size compact and efficient device featuring Bluetooth 5.2 technology and a Nordic nRF52810 chipset. It operates in a wide temperature range of -20°C to +60°C and is built with a durable ABS case that meets an IP67 rating for dust and water resistance. Powered by a 120mAh CR1631 battery, it provides a battery life of up to 6 months with a 0dBm TX power and 1-second advertising interval. The beacon also has a configurable TX power from -20dBm to +4dBm and can be optionally equipped with a G-Sensor. It offers a broadcast range of 50 meters, making it suitable for various wireless connectivity needs. Model No. TS-2103B Bluetooth Version Bluetooth 5.2 Chipset Nordic nRF52 Series TX Power -20~+4 dBm (Configurable) Distance 50m Battery CR1631 (Replaceable) Battery Life 6 Months (0dBm, 1s) Color White Size Φ23*8mm G-sensor Optional OEM Custom color, Print Logo, OEM Package, Software
In the dynamic landscape of workforce management, the TS-2101C Bluetooth Beacon Card, powered by the Nordic nRF52810 chipset, emerges as a pioneering solution for employee tracking. This beacon card is designed to streamline operations, improve safety, and optimize employee efficiency across various industries. Introduction to the TS-2101C Bluetooth Beacon Card The TS-2101C is a beacon card that leverages the latest Bluetooth 5.2 technology to provide precise employee tracking. Its ABS case material ensures durability, while the IP67 rating confirms its resistance to dust and water, making it suitable for diverse working environments. Battery Life and Capacity The Bluetooth beacon card is equipped with an 800mAh Lithium Manganese battery, which guarantees an impressive battery life of up to three years at 0dBm with a 1-second advertising interval. This extended lifespan minimizes the need for frequent battery changes, reducing maintenance costs and downtime. Operating Temperature and Durability Capable of operating in temperatures ranging from -20 to +60 degrees Celsius, the TS-2101C is built to withstand extreme conditions. Its robust design ensures consistent performance, whether it’s deployed in a cold warehouse or a hot manufacturing facility. Customization and Optional Features The beacon card offers a range of optional features to cater to specific tracking needs. Button function customization allows for tailored interactions, while NFC capability simplifies data access and transfer. The addition of AoA (Angle of Arrival) technology enhances location accuracy, and the G-Sensor can monitor the movement and status of employees in real-time. Communication and Range With a configurable transmission power from -20dBm to +4dBm and an adjustable advertising interval, the TS-2101C ensures efficient communication with connected devices. The 50-meter broadcast range is ideal for large facilities, ensuring comprehensive coverage for tracking purposes. Applications in Employee Tracking The TS-2101C Bluetooth beacon card is a versatile tool for employee tracking in various settings. In healthcare, it can monitor staff movements to ensure quick response times in emergencies. In manufacturing, it can track employee locations to optimize workflow and enhance safety protocols. In large office spaces, it can facilitate resource allocation and improve communication among teams. The Bluetooth Beacon Card’s Role in Employee Tracking The primary function of the TS-2101C as a Bluetooth beacon card is to enable real-time employee tracking. By broadcasting signals to connected devices, it allows employers to monitor employee locations, movement patterns, and status, facilitating better workforce management and operational planning. Conclusion The TS-2101C Bluetooth Beacon Card is a testament to the power of technology in enhancing employee tracking. Its advanced features, durability, extended battery life, and customizable options make it an invaluable asset for businesses looking to optimize their workforce management strategies. As companies continue to seek innovative ways to improve efficiency and safety, the TS-2101C stands as a beacon of progress in employee tracking solutions.
The TS-1105L is a portable, card-like Bluetooth Beacon device that uses a Bluetooth low-power chip design and features low power consumption and small size. It is equipped with a CR2032 battery that can last up to two years at 1s broadcast frequency. Model No. TS-1105L Bluetooth Version Bluetooth 5.1 Chipset Dialog DA145 Series TX Power -19.5~+2.5 dBm, Default +2.5dBm OTA YES Distance 60m Battery CR 2032 (Replaceable) Battery Life 2 Years Certification BQB, FCC, CE, SRRC, RoHS, REACH Color White Weight 7g Size 46*41*6mm OEM Custom color, Print Logo, OEM Package, Software
- bluetooth beacon
- ble tag
(and 1 more)
Tagged with:
TS-1106L is a low-cost portable Bluetooth tag, using a low-power chip design, with ultra-low power consumption, and a small size of remarkable characteristics. It supports the standard iBeacon protocol, also supports the ordinary broadcast protocol, and can be an open data protocol, with the Bluetooth gateway, can be widely used in item tracking, asset management, and other industries. Model No. TS-1106L Bluetooth Version Bluetooth 5.1 Chipset Dialog DA145 Series TX Power -19.5~+2.5 dBm, Default +2.5dBm OTA YES Distance 60m Battery CR 2032 (Replaceable) Battery Life 2 Years Certification BQB, FCC, CE, SRRC, RoHS, REACH Color White, Black Weight 6.3g Size 33.8*23.6*5.4mm OEM Custom color, Print Logo, OEM Package, Software
- bluetooth beacon
- ble beacon
(and 1 more)
Tagged with:
