Showing results for tags 'lithium polymer'.
Nowadays, Lithium batteries are used extensively in portable devices, such as cellphones, laptop computers, electronic gadgets, … etc. There is a standard industry-defined procedure (cycle) for charging the lithium-ion/lithium-polymer batteries, otherwise, the lifetime of the batteries is reduced significantly or even they might explode and catch fire. As a basic rule of thumb, a lithium battery should be charged at the rate of 0.5C to 1C. In this article/video, I have introduced a universal double lithium battery charger that the charging current (C rate) can be adjusted simply by changing a resistor value. You just need a 5V power source (such as a mobile charger) and a USB Type-C cable. To design the schematic and PC, I used Altium Designer 22 and the SamacSys component libraries (Altium Plugin). To get high-quality PCB boards, I sent the Gerbers to PCBWay and purchased original components using componentsearchengine.com. To examine the charging current/voltage, I used the Siglent SDM3045X multimeter. Isn’t cool?!, So let’s get started! References Ref: https://www.pcbway.com/blog/technology/Double_Lithium_Ion_Lithium_Polymer_USB_Type_C_Charger_863d1ae1.html [1]: MCP73831 datasheet: http://ww1.microchip.com/downloads/en/DeviceDoc/20001984g.pdf [2]: MCP73831 schematic symbol, PCB footprint, 3D model: https://componentsearchengine.com/part-view/MCP73831T-2DCI%2FOT/Microchip [3]: Electronic designing CAD software plugins: https://www.samacsys.com/library-loader-help [4]: Altium Designer plugin: https://www.samacsys.com/altium-designer-library-instructions [5]: Siglent SDM3045X multimeter: https://siglentna.com/digital-multimeters/sdm3045x-digital-multimeter/ Altium Designer + License (Free): https://www.altium.com/yt/myvanitar
- lithium
- lithium ion
(and 3 more)
Tagged with:
