Jump to content
Electronics-Lab.com Community
Unipolar Stepper Motor Controller using UCN5804
MP
I was looking at the following project:
http://www.electronics-lab.com/projects/motor_light/004/index.html
and in comparing the data sheet with the project schematic, it appears that there is an error. Pins 2 and 7 of the chip are internally grounded. Therefore resistors 1 and 2 are in the wrong place. You will need resistance between your supply voltage and these pins of the chip. If you follow this schematic, you will surely let the smoke out of your chip (or power source), and we wouldn't want to do that. ;)
The small board layout is ok, since it does not add a trace for this.
Has anyone built this circuit? Would like to know how it went.
MP
Link to comment
Share on other sites
In further investigation, it looks as though the data sheet diagram for internal circuitry is not quite right. Where it shows ground, must have some resistance built in that the manufacturer is not showing. If you look at the example circuit given in the data sheet, it also shows the power supply connected directly to these pins (internal ground).
I have attached the data sheet for others to comment.
My original question: Has anyone else used this chip for their steppers? I would like to verify these discrepancies before actually building something on the workbench. I have in the past used other methods for stepper control. This seems like a very easy solution for small 6 wire stepper motors.
MP
UCN5804B.pdf
Link to comment
  • 2 years later...
You can purchase them at:
Futurlec electronics:
http://www.futurlec.com/Others/UCN5804Bpr.shtml
American Micro Semi:
http://store.americanmicrosemiconductor.com/ucn5804b.html?gclid=CKSGlr7VzoMCFShCDgod8FAG8A
Farnell in One:
http://ie.farnell.com/jsp/endecaSearch/searchPage2.jsp?Ntt=ucn5804b&Nty=1&N=401&Ntk=gensearch
Hope it is helpful.
MP
Link to comment
Guest
Reply to this topic...
  Only 75 emoji are allowed.
Loading...
  • Create New...
