Watoto Posted April 16, 2004 Report Posted April 16, 2004 Hello everyone! I need a help with my H-brdge(L6203) circuit to drive my Motor. I have 12V at Out-pot J1-1 and 0V at Out-pot J1-2. Ideally that is enough to drive the motor but when I connect the motor nothing happen and both Output terminals are at 12V. It seems that my Motor short cicuirt. When I manually connect the negative to ground, it works. However, I need to connect both terminal to the motor so that I can reverse direction when voltage output volatge from H-Bridge switch. I welcome all idea or solution. Is there any switch or isolation or relay I can use and how because I need to both terminal to control motor for directionThank you Watoto Quote
MP Posted April 16, 2004 Report Posted April 16, 2004 From your description, it sounds as if you do not have enough current to your H bridge circuit. Check out this link for more on H bridge circuits. However, you might be able to just increase the current available to your present circuit and make it work.http://home.cogeco.ca/~rpaisley4/HBridge.htmlMP Quote
