Hi
I have build a headphone buffer amplifier but there is a problem.
at first the sound is weak then as the NE5532 becomes hot the sound increases untile the IC becomes very hot and then Hiss in sound appeares i have also made some changes, i have used a 100K Pot instead a !00K pot for every IC so that I can control the volume of all just by one Pot...
the schemtic is attached...
your help is appreciated in advance...
Headphone_Buffer_Amp.pdf
Hi
ooooooooooooh
I Myself found the answer and this is the greatest exprience in my life
I had forgotton to solder one of the jumpers whic was related to -Vee Net,
so we take this result that if you forget to solder -Vee then the NE5532 gets hot and the device do NOT work properly ;D so remember to count the jumpers when you finished soldering, but I expected Distortion in case the Lack of -Vee but why the things i said above happened?
Anyway I am very happy
