toXic Posted December 4, 2004 Report Share Posted December 4, 2004 Hey guys. I was just wondering how you could find parts to make like a sensor that could hook up to a solenoid, so that the solenoid dosent shoot unless the object is in the sensors eye or sight. Quote Link to comment Share on other sites More sharing options...
ante Posted December 4, 2004 Report Share Posted December 4, 2004 Hi toXic,Welcome to this forum.Can you explain in more detail what you want to do? What kind of object do you want to sense, is it metal or plastic what shape? The more details you supply the better solution you can get. Pictures will help. Quote Link to comment Share on other sites More sharing options...
toXic Posted December 15, 2004 Author Report Share Posted December 15, 2004 sry been gone a lil while. But anyway it would be detecting Sphere objects. They would be paintballs. They are 68 calliber and filled with a thick milky liquid. they are like plasticy (hard) on the shell. Just curious how to make one. It needs to be able to run off of 1 or 2 9v batteries. And connect to a solenoid. And if it dont sense a ball the solenioid wont shoot. ty Quote Link to comment Share on other sites More sharing options...
CRE Posted December 15, 2004 Report Share Posted December 15, 2004 Well, first does the solenoid just turn on once? or is it on until the path is cleared? If it's the first a 555 timer setup as a monostable vibrator would work.Second, if sensed optically can the sensor/emitter be placed opposite eachother? If yes then I'd probably first experiment with a LDR and transistor opposite an LED. Use IR if visible light is a problem. Quote Link to comment Share on other sites More sharing options...
toXic Posted December 16, 2004 Author Report Share Posted December 16, 2004 Well the solenoid would go off everytime the trigger would be pulled. Which could be up to 20 times a second. So the eye would need to be able to keep up wiht it. The Sensor can be placed where it is opposite. but most made for this purpose is only used on one side. Quote Link to comment Share on other sites More sharing options...
