Jump to content
Electronics-Lab.com Community
need a delay
It sounds like you want a sequential timer.
I take it that you want the second relay to turn off after a certain amount of time. This circuit is negative edge trigger, when the trigger is connected to 0V, if you want posative connect the input to 0V with a transistor. OUTPUT 1 will be on for a certain amount of time then turn off and OUTPUT 2 will come on. Connect the outputs directly to the relays (with a diode in reverse parallel)
EDIT: Just remembered the schematic.
Any questions are welcome.
Link to comment
Share on other sites
Guest
Reply to this topic...
  Only 75 emoji are allowed.
Loading...
  • Create New...
