jawaking00 Posted February 24, 2005 Report Share Posted February 24, 2005 Hello,Where I work, we just recieved a Fluke 434 Power Analyzer. http://us.fluke.com/usen/products/Fluke+430+Series.htm?catalog_name=FlukeUnitedStates The thing is, that it can only be setup to analyze lines running with 50 or 60 Hz power. The 3-Phase power we have here is all running at 400 Hz.What I'm wondering is whether or not anyone knows what would happen if I hooked this up to this higher frequency power? I really don't want to destroy this $4000 dollar piece of equipment, but at the same time, it really doesn't do me any good if I can't use it to analyze any of the power here.Any help or suggestions would be greatly appreciated.Thanks!! Quote Link to comment Share on other sites More sharing options...
prateeksikka Posted February 24, 2005 Report Share Posted February 24, 2005 hi jawaking!may i know the power level at which you are working at your place?if it is upto few watts(within TTL RANGE),YOU CAN USE A RIPPLE COUNTER ,A MOD 8 COUNTER WITH 8 STATES WILL DO THE JOB FOR YOU.YOU MAY HAVE TO APPLY SOME ADDITIONAL CIRCUIT JUST LIKE IN CASE U HAVE SINE WAVE,YOU MAY HAVE TO USE A CONVERTER WHICH CONVERTS TO SQUARE WAVE.AT O/P OF LAST FLIP FLOP IN COUNTER,YOU GET FREQUENCY OF 400/8=50 Hz.YOU CAN ALSO USE FREQUENCY CHANGER ICs.BUT FIRST ONE WILL BE BETTER CHOICE.PRATEEK Quote Link to comment Share on other sites More sharing options...
ante Posted February 25, 2005 Report Share Posted February 25, 2005 Hi jawaking.3-Phase 400Hz must be aircraft power you are dealing with? Quote Link to comment Share on other sites More sharing options...
