rdmotors Posted February 28, 2005 Report Share Posted February 28, 2005 I have two questions in this area of digital readouts:1) Is there a project here that uses old pc mice parts to create the signals for a DRO?I have noticed that HP printers have a marked tape behind the print head. It uses an optical device in conjuction with this, I guess for location, so secondly:2) Could this be used to create signals for a DRO?I know I will be limited by the length of the tape for reading purposes, but my mill that I am building is small. Being my first one I want to try and test it all before moving up to a bigger unit. I hope to use the first unit to build the next. Since it will help me cut a straight line and make a hole perpendicular or parallel to that line the second machine should be better. I have the mechanical ability to design and build just not the ability to do it square or straight. I hope this first project will correct my inaccuracies and help me learn more about the electronics of it all. So next time I can build that better "mouse trap". Quote Link to comment Share on other sites More sharing options...
audioguru Posted February 28, 2005 Report Share Posted February 28, 2005 Hi RD,You have a good idea that is just the beginning of having computerized cutting and drilling. Just use an HP printer to carry a laser cutter wherever you want!You can use the tape and optics to drive an electronic counter with display, similar to a pedometer (walking steps counter). Search for a circuit in Google.Maybe you could use your own belt that turns the optical wheel from a PC mouse. Quote Link to comment Share on other sites More sharing options...
rdmotors Posted March 1, 2005 Author Report Share Posted March 1, 2005 Audioguru Funny you should say that I am using lots of the parts from the printers for the unit including the stepper motors, slides, slider rods, and other pieces. I did leave the laser alone though, from the laserjet since I tought it wouldnt be powerful enough. ;D I will look for the circuit and see what I can come up with. I do have a few mice I could use and see if I could gear drive the wheel but the problem I have is the actual circuit for that. I would want this to send the signals straight to a readout and not into my controller (computer). I have seen articles on this before but no where near what I would need to be able to follow it. In the mean time I will look for the other circuit and see what I can come up with........ Quote Link to comment Share on other sites More sharing options...
