Skeith Posted June 27, 2005 Report Share Posted June 27, 2005 I need an audio transformer for a Push pull 6V6 14watt tube amp I have built.The impedance on the secondary needs to be 8 ohms, while the impedance on the primary isn't stated on the schematic. from the look of it i probably need something between 2K ohms and 4K ohms center tapped. I cant find a sutable transformer for this. I was wondering if I could rewind a power transformer or something. Or if there is some other way I can get a matched impedance for the speaker.thanks. Quote Link to comment Share on other sites More sharing options...
francis Posted July 6, 2005 Report Share Posted July 6, 2005 If you really want to make your own, here's some good general info (maybe a little too much, actually...)http://www.geofex.com/Article_Folders/xformer_des/xformer.htm Quote Link to comment Share on other sites More sharing options...
hotwaterwizard Posted July 9, 2005 Report Share Posted July 9, 2005 Here are a few 6v6 schematics. maybe one of them can help you figure it out.Tube amps 6v6[img width=680 height=594][img width=680 height=416][img width=680 height=567] Quote Link to comment Share on other sites More sharing options...
