EdwardM Posted January 20, 2006 Report Posted January 20, 2006 HiFor some years now I've used a simple way of protoyping on 0.1in perforated boards which usually guarantees first time working. I simply make an outline of each IC and pin name used as well as power supply terminals in a drawing program and then print them on paper. Each outline is then stuck down on the perforated board using paper glue. It's then very easy to follow your circuit diagram to join up each node of the circuit and it's a very useful aid in debugging.My favourite program is Visio, I'm sure there are many others, where you set up a 0.1in printing grid for each drawing and just add IC's until the page is full, I then cut out shapes as necessary, using a scalpel, and glue them to the perforated board.As an example, here's one I made much earlier.No doubt there are many using this idea, but so far I haven't met themEnjoyEd Quote
MP Posted January 21, 2006 Report Posted January 21, 2006 I might add to this, that if you are using a circuit board program that creates a silk screen image of the components automatically, you can print this and do the same. I think this is an excellent idea. A little clay or flux in the holes and you could spray a light laquer or conformal coat to the surface and it would be permanent.MP Quote
EdwardM Posted January 21, 2006 Author Report Posted January 21, 2006 Thanks MPthe conformal coating is a good idea and should enable the transition from prototype to 'production'. The reason for posting this idea was mainly to pass on the results of a lot of frustration when designs didn't work, whether mine or someone elses'. Many is the hour I've spent debugging a circuit only to find that I'd inadvertently joined A to B instead of B to C and if you are not sure whether the design or wiring is correct then inevitably getting the thing working seems to take forever.So, if you can take one variable out of the equation - Life Gets EasierCheersEd Quote
gogo2520 Posted January 22, 2006 Report Posted January 22, 2006 Those are good ideas, next time I do a strip board I'll try it. I got a question what is conformal coating. Is that like lacquer? gogo Quote
EdwardM Posted January 22, 2006 Author Report Posted January 22, 2006 Hi gogoI believe so, I think it is to prevent moisture interfering with components and the PC board and altering their electrical characteristics.Ed Quote
