Kelly_41m Posted January 25, 2006 Report Share Posted January 25, 2006 Been looking for a data sheet on this ( TD6342P ) part now for quite some time with no success. I emailed Toshiba regarding this matter and not sure if I got an automated response, but it ( the response ) simply stated the part is obosolete and no data available. Anyone out there know anything about this part. Sure would like to hear from you.Kind RegardsKelly_41m Quote Link to comment Share on other sites More sharing options...
hotwaterwizard Posted January 26, 2006 Report Share Posted January 26, 2006 Wow I see why you have had trouble finding it. Here is the closest Datasheet I could find to that number. TD6347FPlease make double sure you got all of the letters and numbers right. TD6342PTD6347.pdf Quote Link to comment Share on other sites More sharing options...
Kelly_41m Posted January 26, 2006 Author Report Share Posted January 26, 2006 Thanks for your effort there HotWaterWizard, is appreciated. The part number is correct, taken directly off the IC I suspect as failed. In reality as I've not been successful in tracking this part down, I've double, tripple and quadruple checked the part number many times. Ive come across a few sites in China and Japan that have the part as a stocked item, but again no data sheets. I guess what I'm hoping for is someone out there who has Toshiba data books as part of thier library ( circa late 80's, mid 90's ) who would be willing to take the time to scan, even if its just the pinouts, the information regarding this part and forward it to [email protected]. I would be eternally gratefull. While on the subject of data books, I myself have a fairly extensive library late 80's to mid 90's.Motorola ( Almost complete set )National Semi ( Almost complete set )Microchip ( Micro controllers and embedded devices )Analog Devices ( Almost complete set )Linear Technology ( Almost complete set )NEC Intel ( Almost complete set )Texas Instruments ( Almost complete set )Fujitsu ( Memory, Peripherals and CPU's )Silconix ( Power )International Rectifier ( Power )Signetics SharpSGS ThompsonStandard Micro SystemsZilogOkiSiemensHitachiDallasAnd Miscellaneous other books.Thus, if there is someone out there with Toshiba info, maybe we can swap info.RegardsKelly_41m Quote Link to comment Share on other sites More sharing options...
Kelly_41m Posted January 26, 2006 Author Report Share Posted January 26, 2006 Found a little bit of info on this unit on a Chinese web site as per the attached pic.The unit is listed as a Toshiba interface IC, and if I'm interpreting what I see correctly, should be listed on Page 121 ?? in the Toshiba Interface IC Book ??Sure would like to find some info on this puppy.Kind RegardsKelly_41m Quote Link to comment Share on other sites More sharing options...
hotwaterwizard Posted January 28, 2006 Report Share Posted January 28, 2006 TD6342PInterface, I Quote Link to comment Share on other sites More sharing options...
