ManowarDave Posted February 20, 2006 Report Share Posted February 20, 2006 Hi there,I'm a complete newb to this board and am after a little assistance with my first major project.I am trying to put together a variable DC power supply capable of providing 0-130VDC at about 1.5Amps for the purposes of anodizing titanium.I have not found much in the way of this kind of thing on the web and what I have found hasn't quite answered all of my questions.The basic design I am working from can be found here http://www.mrtitanium.com/anodizer.htmlI am working with a variac rated to 3Amps leading into a full wave bridge rectifier. The DC output is then run over a 3300uF 350V Cap to be smoothed before going to the anode and cathode. The above article has a light bulb bridging the cap to "take the load" and act a cap drain but the article says this can be replaced with a power resistor rated at 100ohm 200W.Well I got myself 2 power resistors (50ohm 100W for lack of the former as a single unit) in series. Now these babies get really hot, and this is what's worrying me. Are they going to blow?If I take these resistors out of the circuit then I loose the variable aspect of the circuit as the cap keeps the voltage up with no load on if I need to turn the voltage down with the anode out of the anodizing bath.Really, what I would like help on is, a) are these Resistors up to the job, b) if not what do I need to replace them with, or c) does the whole thing need to be re-thunk?Many thanks in advance for your help and patience.Dave Quote Link to comment Share on other sites More sharing options...
