trienbang431986 Posted April 13, 2006 Report Share Posted April 13, 2006 How to view real size of this file? Quote Link to comment Share on other sites More sharing options...
stoi2m1 Posted November 18, 2006 Report Share Posted November 18, 2006 There are 2 sizes to every image on a computer. The first size is the image in pixels, which is how we view it and how it is displayed on a computer monitor. The second size is the print size. Different software will handle this in different ways. The secong size is the print resolution which is defined at pixels per square inch or pixels per cm square. So if you have and image which is 100 x 100 pixels and the resolution is 100 pixels/inch. The image will print out 1 sqaure inch. If the reslotion is 50 pixels/inch the image will print out to be 2 square inches. If the resolution is 200 pixels/inch the image will print out .5 square inches. Now you have to figure how the image size of the file in pixels and then define the print resoution in the software you are using to get the appropriate size. The setting may have been known by the origional creator of the artwork. But the file itself will not contain the print resolution data. You will have to do some test print and lay your components on it to determine when the settings are correct. Or use the grid option of your image editor and an approtiate resolution to detemine if the component holes are layed out in the appropriate locations.Good Luck,Jesse Quote Link to comment Share on other sites More sharing options...
MP Posted November 22, 2006 Report Share Posted November 22, 2006 Trienbang,Your DIP or SIP packages on this board most likely have their holes on 0.1" centers (2.54mm). It is pretty standard. Print and measure, then tweak on the size if needed.MP Quote Link to comment Share on other sites More sharing options...
shaiqbashir Posted December 22, 2006 Report Share Posted December 22, 2006 call it in the Photoshop and see its image size in INCHES. Quote Link to comment Share on other sites More sharing options...
ARUN CHOWDARY Posted November 4, 2010 Report Share Posted November 4, 2010 what do you mean by the real size is in the centi meters or inches or in the resolution Quote Link to comment Share on other sites More sharing options...
amadjo_01 Posted November 24, 2010 Report Share Posted November 24, 2010 if you are using Proteus software, you can set your PCB by setting first the work area,(in inches or in cenrimeters)then just follow the box, and there you have it, :D Quote Link to comment Share on other sites More sharing options...
