vbSteve Posted October 10, 2006 Report Share Posted October 10, 2006 Hi,I'm new to electronics, well new, I mean I know the basic theory of electricity. You guys don't mind if I ask noob questions here not? I'm actually better at coding in Visual C++ and Visual Basic :)I'd like to know what influence an IR beam has on a photodiode, a diode with 3 pins.I'd like to light a green LED whenever the IR receiver receives. I have other intentions with it, but I guess this is the simple way of explaining.Eventually it will be used in a computer controlled doorlock, where when the IR beam is established, it returns "1" (= "closed/connected") to the parallel port.So what do I need to do in order to light the LED. Nothing to fancy stuff please. I search the net, but there is just so little information about it (Or maybe i was looking at the wrong sites)Here is image that might help:Thanks in advance. Quote Link to comment Share on other sites More sharing options...
Sukhbinder Posted October 10, 2006 Report Share Posted October 10, 2006 Hi vbSteve, wellcome to the world of electronics, its not too difficult to learn electronics, if u know some basic hardware concepts well then with ur current knowldge of C++ and VB things will be piece of cake. back to ur query, u said that u have a three terminal photodiode, well in ur case u must be refering to a photo transistor as a diode (di= 2) is a 2 terminal device. a photodiode is used in the reverse bias mode and when IR light falls on the junction minority carriers are generated which cause the diode current for detection. a photodiode will work in any visible wavelength also but the case is made such that it filters out all radiation except IR ( this prevents the device from being activated in ambient light). u are using a phototransistor which is like a normal transistir except for the case that it is switches on by the light and not the base current (u may have a little base bias to allow for proper switching. u can connect the green led between the phototransistor emitter and ground. and remember to connect the phototransistor collector to the positive supply through a current limit resistor. when the IR falls on the phottransistor it will switch on and start conducting and the LED will glow. ;) Quote Link to comment Share on other sites More sharing options...
vbSteve Posted October 10, 2006 Author Report Share Posted October 10, 2006 hmm, sounds complicated. So I have to treat it as a transistor? How many Ohms does the resistor need to be?And how does a receiver with 2 pens work? like a simple switch?Ah, sorry, just experimenting,see whats the easiest ;) Quote Link to comment Share on other sites More sharing options...
Sukhbinder Posted October 11, 2006 Report Share Posted October 11, 2006 use the equation R=(Vcc-Vled)/Iled. Vcc is ur supply voltage, Vled is the led forward voltage drop (usually 2-2.2 volts for green leds), Iled is the green led current u need (check up its data sheet for the recommended value, usually normal leds work at 2-5mA and high efficiency leds can work at 10-20mA). i suggest that u stick to the phototransistor as its easier for u to use. a photodiode is connected in reverse bias with a limiting resistor, it works best with a pulsed signal but it cannot give enough current to drive ur LED. a photodiode must be used with a buffer circuit to boost the current (or u may say that the diode is the sensor but the transistor can act as a switch). the advantage of a transistor is its higher current switching and higher sensitivity but it has a lower bandwidth (upto a few hundred KHz) while a diode has a very low current but has a very high bandwidth (few MHz). u can also use the IR detectors used in the TV remotes like the TSOP1738, u just need to connect to Vcc and ground and the 3rd pin for the o/p goes low when it detects an IR signal. u can connect a transistor to invet its output and drive the LED. u'll need a pulsed signal at about 38Khz for the transmitter. here is the data sheet for it check out its detection frequency rangeTSOP1738.pdf Quote Link to comment Share on other sites More sharing options...
vbSteve Posted October 11, 2006 Author Report Share Posted October 11, 2006 Ah of cource, the Ohms Law, how could I forget that! :PWell I guess I will be using the phototransistor then :)Another thing, when I bundle the IR beam (using a lens or something) , is it possible to increase the range between the IR LED and the diode? Probably not relevant to my project now, but it's good to know :) Quote Link to comment Share on other sites More sharing options...
Sukhbinder Posted October 12, 2006 Report Share Posted October 12, 2006 generally all IR diode packages are made such that the field of emission is limited, a lens may help collimate the beam but won't improve the range much. to improve the range u'll need to use two IR diodes. ( as seen in some older TV remotes, it improved the range and also the field of emission so the remote could be used from different angles from the detector) ;D Quote Link to comment Share on other sites More sharing options...
vbSteve Posted October 13, 2006 Author Report Share Posted October 13, 2006 Cool it worked! Thanks! ;D Quote Link to comment Share on other sites More sharing options...
