sssaaa Posted December 28, 2006 Report Posted December 28, 2006 i didnt found NTE123AP transistor in my city.what transistor i will use in the place of this transistor.thanks Quote
sssaaa Posted December 28, 2006 Author Report Posted December 28, 2006 Hi AudioguruI m using ur FM transmitter you said it will not work on less then 5 volts.it also worked on 2.5volts? why?I m using transistor shaped voltage regulator IC like yours. Quote
audioguru Posted December 28, 2006 Report Posted December 28, 2006 I designed the biasing of the preamp transistor for a regulated 5V supply so it could have enough voltage gain.With a higher voltage then it is saturated. With only 2.5V then it is cutoff as my simulation shows: Quote
sssaaa Posted December 29, 2006 Author Report Posted December 29, 2006 sorry i forgot to mention that I m using this preamp with your transmitterhttp://www.uoguelph.ca/~antoon/circ/preamp.htmand your transmitter is worked when my battery voltage goes down to 2.5 voltsIt means its oscillator which is connected with voltage regulator IC, and rf amp transistor which is connected directly, will also work on 2.5 volts ? Quote
audioguru Posted December 29, 2006 Report Posted December 29, 2006 sorry i forgot to mention that I m using this preamp with your transmitterhttp://www.uoguelph.ca/~antoon/circ/preamp.htmand your transmitter is worked when my battery voltage goes down to 2.5 voltsMy transitter already has a preamp transistor. I showed a sim with it cutoff and not working with a supply voltage of only 2.5V.My transmitter is very sensitive to sounds. Adding another preamp would overload its input.I also simulated the "preamp" circuit you found and it saturates with nearly any supply voltage because it is not designed properly. Quote
sssaaa Posted January 4, 2007 Author Report Posted January 4, 2007 i have two questions to ask you1, Your transmitter`s oscillator and rf amp works on 2.5 volts?2, what is the output of LM2931A on 2.5 volts?thanks Quote
