kylefrink Posted February 28, 2010 Report Share Posted February 28, 2010 120volt to +36v-0-36v transformer From (3) 12volt ct transformers? is it possible. Quote Link to comment Share on other sites More sharing options...
Alex Tsekenis Posted February 28, 2010 Report Share Posted February 28, 2010 No. Not even worth thinking about it. Quote Link to comment Share on other sites More sharing options...
audioguru Posted February 28, 2010 Report Share Posted February 28, 2010 Hi Kyle,Once again, you do not know that a 26VAC transformer has a peak poltage of 36.8V and the rectifiers will charge the filter capacitors to about 35VDC.Your 25V transformer with two 25VAC windings will make a power supply that is about plus and minus 33VDC. The LM3886 will have an output of 53W into 8 ohms. Quote Link to comment Share on other sites More sharing options...
