numanali Posted March 25, 2010 Report Share Posted March 25, 2010 hi everyone...my friend give me a task to install a an alarm circuit i his little industry.....he gave me instructions that a circuit should alarm after every 30 minutes,and it must only stops when any worker press the button,and when button is pressed the timer must restart ...every time a button is pressed. ckt should acknowledge the computer (data logging) the time button is pressed..so i thought to use at89c2051 for this purpose i have made the ckt prototype....but still some problems are there, i have to design a driver ckt to on the alarm.and i dont know how to do data logging on pc...by rs485...this is the circuit i designed but it didnt run according to program....so modify my prog for other micro controller trainer i have....the program runs fine ....now the modifications i want in my hardware is seven segment display of timer and it wud be better if timer can be set by user inputs through switches... can u guide me what modifications i must do in my circuit..plz help i want to make this thing like professional.ORG 00HMOV SP,#60MOV TMOD,#21H ;TIMER 1 MODE 2, TIMER 0 MODE 1MOV TH1,#-3 ;9600 BAUD RATEMOV SCON,#50H ; SERIAL MODE SPECIFIERPROGR: MOV P1,#00HMOV P3,#00HACALL DELAY;---------------------------------------CANB: MOV TMOD,#01HSETB P1.7 ;BUZZER INDICATOR OFFSETB P1.4 ;ATTENDANCE INDICATOR OFFSETB P1.1 ;SYSTEM BUSY INDICATOR OFFCLR P1.3 ;RELAY OFFSETB P1.0 ;BUZZER ONACALL DELAYCLR P1.0 ;BUZER OFF;----------------------------------------REPEAT: CLR P1.1 ;SYSYTEM BUSY ONACALL DELAY30MSETB P1.1 ;SYSTEM BUSY LED OFFSETB P1.0 ;BUZZER ONSETB P1.3 ;RELAY ONCLR P1.7 ;BUZZER INDIACTOR ONSETB P1.2 ;MAKE P1.2 INPUT PORTSWITCH: JNB P1.2,SWITCHCLR P1.0 ; BUZZER OFFCLR P1.3 ; RELAY OFSETB P1.7; BUZZER INDICATOR OFF;-----------------------------------------------SERIAL: SETB TR1MOV DPTR,#MYDATASER_1: CLR AMOVC A,@A+DPTRJZ REPEATACALL TRANSMITINC DPTRSJMP SER_1TRANSMIT:MOV SBUF,AT_1: JNB TI,T_1CLR TIRET;----------------------------------------DELAY: MOV R4,#100DL1: MOV R5,#200DL2: MOV R6,#200DL3: DJNZ R6,DL3DJNZ R5,DL2DJNZ R4,DL1RET;----------------------------------------DELAY30M:MAIN: MOV R1,#9MAIN1: MOV R2,#200MAIN2: ACALL TIMERDJNZ R2,MAIN2DJNZ R1,MAIN1RETTIMER:BACK: MOV TH0,#4BH ; FOR 50MSMOV TL0,#0FDHSETB TR0TIM: JNB TF0,TIMCLR TR0CLR TF0RETMTDATA : DB 'MACHINE ATTENDED',0;----------------------------------------END Quote Link to comment Share on other sites More sharing options...
