dikkysun Posted April 2, 2010 Report Share Posted April 2, 2010 i have got an aircraft airbone audio entertainment device,right now i Would like to use in civilian.Voltage 6 volts,but Current frequency is 400hz,so does the generally voltage work?MODERATOR EDIT:Spam removed. Quote Link to comment Share on other sites More sharing options...
audioguru Posted April 2, 2010 Report Share Posted April 2, 2010 I have got an aircraft airbone audio entertainment device,right now i Would like to use in civilian.Voltage 6 volts,but Current frequency is 400hz,so does the generally voltage work?If it is powered from 6VAC/400Hz then the main filter capacitor must have its value increased 8 times if a 50Hz frequency is used.It might be easier to power it from a DC wall-wart if you can measure how many DC volts it needs. Quote Link to comment Share on other sites More sharing options...
