Usmani Posted May 2, 2010 Report Share Posted May 2, 2010 Hi there..I am new at this forum..i need ckt diagram of ups or inverter(12v DC to 220v AC, 50 hz) approx 2KV..if ckt of 2KV is not available,then 1 kv or more..would any one help me in getting it???I'll look forward to u..also chk out link below and comment, if it is implementable..Thanks :)http://www.qsl.net/dg5sga/inverter.htm Quote Link to comment Share on other sites More sharing options...
audioguru Posted May 3, 2010 Report Share Posted May 3, 2010 2kV is a voltage, not a power. W is Watts which is power.Do you want a max power of 2kW?It is impractical because the current from the 12V battery will be an average of 175A and the peak current from the battery will be 247A. A battery will boil or explode. Quote Link to comment Share on other sites More sharing options...
Usmani Posted May 3, 2010 Author Report Share Posted May 3, 2010 Hello Audioguru,thanks for interest n reply..i mistakenly wrote 2kv,it is actually 2kw..if 2kw is impractical design, then tell me about 1.5kw or 1 kw..otherwise share with me whichever ckt u have of ups/inverter..i wanna make it for domestic use..by the way i've seen ups having rating 5kw or less!!! how they be build, if u r saying that 2kw is impractical design??i thing more then 1 bettery will use for these high power inverters..i'll wait for ur +ve reply..thanks.. Quote Link to comment Share on other sites More sharing options...
