nikyc Posted August 22, 2010 Report Share Posted August 22, 2010 Hy,I'm trying to build a robotic arm using a couple of servomotor's. The connection between the servomotor and the parallel port is made with the circuit in the attached schematic.The command code is self made in VC++, and creates a signal with the following specifications: period - 20ms, pulse width - between 1,5 and 2,9 ms (tested).Now... the servo is running but very slow (a complet spin takes around 2 minutes) and not continuously.What in the world can be wrong here?! Please help...... Quote Link to comment Share on other sites More sharing options...
