BOsborne Posted May 11, 2011 Report Share Posted May 11, 2011 Just a small sample of components that I have collected over the years.Unlike most sellers at Ebay, I don't try to make money from shipping.I will send by the lowest cost and not charge for packaging. I get free packaging from mywork place from our shipping department, so I recycle our received items packages.I am here to help fellow electronics enthusiasts like myself.I have several of each of these. You can find the Data Sheets for them here:http://www.datasheetarchive.com/uA715HC high speed op ampuA733HMQB Differential Video Amplifier op ampMC14011BAL Motorola 2-Input NAND-Function Logic Gate 9601DMQB Retriggerable One ShotDM7430N 8-Input NAND GateMC6802 Microprocessor with clock and optional RAMMC10105L Triple 2-3-2-Input OR/NOR GateMC10125L Quad MECL to TTL TransistorMC10131L Dual Type D Master-Slave Flip-FlopMC14050 HEX Buffer7430N 8-Input NAND-Function Logic Gate10524 Quad Ttl-to-mecl Translator54165DMQB 8-Bit Parallel-to-Serial Converter9601DC Retriggerable Monostable MultivibratorAM27S21DC 1,024-Bit (256 x 4) Bipolar PROM DATA SHEET: http://www.datasheetarchive.com/pdf-datasheets/Datasheets-115/DSAP00731.html ICL7109CPL Maxim Integrated Products 12 Bit A/D Converter With 3-State Binary Outputs DATA SHEET: http://www.datasheetarchive.com/pdf-datasheets/Datasheets-18/DSA-346047.htmlCA3028B/3 RCA General Purpose Differential Amplifier - high rel. S68B21P American Microsystems Peripheral Interface Adapter (PIA) - Peripheral I/F Adapter SN54155J Texas Instruments Dual 2 Line to 4 line Decoders/DemultiplexersSNJ54S02J Texas Instruments QUADRUPLE 2-INPUT POSITIVE-NOR GATESMC6840P Motorola Semiconductor Programmable timer module, 1 MHzSN74LS86N Motorola / Freescale Semiconductor QUAD 2-INPUT EXCLUSIVE OR GATE2N3823 Motorola N-CHANNEL JUNCTION FIELD EFFECT TRANSISTOR 4 pinsJAN2N1613 Microsemi Corporation NPN Transistor2N2369A Texas Instruments SMALL SIGNAL NPN TRANSISTOR TO-182N2484 Fairchild Semiconductor NPN low level low noise amplifier.93L425PC Fairchild General-Purpose Static RAM - Includes separate CE, WE cntrlD2148H Intel General-Purpose Static RAM - Icc 150mA maxRM4156DC Raytheon Electronics Quad General Purpose Op Amp - Compensated TRW52602 TRW RF power transistor 2GHz QTY. (2) http://www.advancedsemiconductor.com/pdf/mln2033f.pdfMC14046B Motorola Phase Locked LoopICM7218AIJI Intersil Corporation 8-Digit LED Microprocessor-Compatible Multiplexed Display Decoder Driver.... QTY. (1)DS8830N National Semiconductor Dual Differential Line DriverLF347BN National Semiconductor Wide Bandwidth Quad JFET Input Operational AmplifierLM324AN Motorola Operational Amplifier, General purpose, Quad channel, 32V, DIP, 14-PinCA3028A RCA Differential/Cascode Amplifiers from DC to 120MHz LM311N ST Microelectronics Comparator, Single channel, Open drain/collector, 36V, DIP, 8-pin (QTY. 2)I have a plethora of other components that I will post also.I'm looking for a TDA7000 FM Receiver IC.Trimmer caps 2-45 pf rangeHi frequency power transistors electret condenser microphones330pf ceramic caps Link to comment Share on other sites More sharing options...
