Jump to content
Electronics-Lab.com Community
Sign in to follow this
londevitt
Measuring roller skate wheel rotation
Hello, I want to build a machine that will detect (and thus measure) the rotation of a roller skate wheel as it sits on a roller skate.  The purpose here is to get a quantitative measurement of the bearing units quality.  The plan is to build a machine that will apply a standardized force vector to the wheel and then time how long it spins a result.
Can anyone suggest what is the best kind of sensor to use to detect the rotation of the wheel?
If this is not the correct forum for this question I apologize.
Thank you,
\Lon.
Share this post
Link to post
Share on other sites
Hi Lon,
I assume the roller skates are fixed to a test stand.
Using a permanent magnet on one side of one wheel and a counter weight on the opposite side you won't have any unbalanced situation affecting bearing life time.
Use a hall switch to sense magnet passage (magnet must face the sensor with it's south pole) you can count revolutions employing a simple counter circuit.
Check out the TLE4905 for your purpose and decide if it fits your needs.
HtG
Share this post
Link to post
Hello all,
  What about using a non contact tachometer that uses a refelective tape applied to the rotating surface? This would eliminate or reduce any balance problems using magnets and weights. Take a look at the link for one.
rfranzk.          http://www.amazon.com/Neiko-Professional-Digital-Non-Contact-Tachometer/dp/B000I5LDVC
Share this post
Link to post
Thank you Herman the German and rfranzk your input is much appreciated.
You are correct in thinking the skate will be on a stand.  The application would be a machine in a skate shop or rink where skaters can place their skates and find out how good their bearings are as measured by how long each wheel spins from the standardized force.
I will draw a diagram of the machine and post it for your further comment.
The (magnet/sensor) Hall Effect idea is something I have thought about but abandoned as to cumbersome for an end user device; I am strongly gravitating to doing it optically.
Especially as I am an engineer for an electronics security company and have access to video cameras/DVRs that can do motion detection and alarm circuit triggering which I could then use to control timing circuitry.
Thank you again for your time and consideration.
\Lon.
Share this post
Link to post
Guest
Reply to this topic...
  Only 75 emoji are allowed.
Loading...
  • Create New...
