yaldwyn Posted October 5, 2011 Report Share Posted October 5, 2011 coolbot, which was designed to do just that. I have the system set to keep the room at 52 Fahrenheit and it works great. (The coolbot is designed to keep a room as low as 34 F using only a air conditioner.) However, I would like the fan to shut off when the compressor in the air conditioner is off. I would like to cut down on the airflow in the cheese aging room. Anybody out there who could help me with this?On another forum I got the following answer: Remove the unit from the case. Based on the user manual (no wiring schematic found), the fan speed switch must be supplied directly from the on/off switch for the unit. Rewire so that the fan speed switch is supplied directly from the 120-V line that supplies the compressor. Follow conventional wiring codes for safety.However, when I removed the case from the unit, I got confused by all the electronics and wires. I did find a wiring schematic so I'll post that here with the hope that someone can help me with my question. Thank you very much. Quote Link to comment Share on other sites More sharing options...
