devakuamr Posted November 28, 2011 Report Share Posted November 28, 2011 HI SIR CAN U TEACH ME WHATS THE PROGRAMMING OF MY PROJECT APPENDIX A//====================================================================//Author: Devakumar//Project: Solar powered surveillance system// This source code is used in my project]//====================================================================#include <16f877a.h>#include <math.h>#include <stdlib.h>#fuses HS,NOWDT,NOPROCTECT,NOLVP#use delay (clock=20000000)#use rs232(baud=19200,xmit=PIN_C6,rcv=PIN_C7,PARITY=N.BITS=8)#org 0x100,0x1FFF void loader 16f877 (void) {} //16f677A//input definition//====================================================================#define STO_in_A PIN_A1 //pin3#define STO_in_B PIN_A2 //pin4#define CONT_A PIN_A3 //manually control //pin5#define CONT_B PIN_A4 // Automatic // pin6#define cont_C PIN_A5 // pin7#define SENSOR PIN_C1 //pin16//output definition//====================================================================#define PIC_A 0 //PIN_B7#define PIC_B 1 //PIN_B6#define CAM_A 2 //PIN_B5#define CAM_B 3 //PIN_B4#define BUZZER 4 //PN_B3#define Power_A 5 //PIN_B2#define Power_B 6 //PIN_B1#define ON 1#define OFF 0#define NO_DELAY 0Int 16 adc_result;Int channel_mov, channel _ photo, t;Int8 ctr ;Int8 value;void outssignal(int8 signal_out,int8 state 1,int8 delay_ms1){If signal _out==0){If(state 1 ==0) output_low(PIN_B7); //pin40else output_high(PIN_B7);}if(signal_out==1){If(state1==0) output_low(pin_B6); //pin39else output _high(pin_B6);}if(signal_out==2){If(state1==0) output_low(pin_B5); //pin38else output _high(pin_B5);}if(signal_out==3){If(state1==0) output_low(pin_B4); //pin37else output _high(pin_B4);}if(signal_out==4){If(state1==0) output_low(pin_B3); //pin36else output _high(pin_B3);}if(signal_out==5){If(state1==0) output_low(pin_B2); //pin35else output _high(pin_B3);}if(signal_out==6){If(state1==0) output_low(pin_B1); //pin34else output _high(pin_B1);}delay_ms(delay_ms1);}//main function//====================================================================main(){set_tris_A(0b11111111);setup_adc(ADC_CLOCK_INTERNAL);setup_adc_ports(RA0_ANALOG); //setup_adc_ports(RA0t=20;printf(Start\r\n Quote Link to comment Share on other sites More sharing options...
