veerubiji Posted November 29, 2012 Report Share Posted November 29, 2012 Hi,I am confusing in calculating permitivity of the fluid. Permittivity differs from one fluid to another.Ɛ=ƐrƐ0.Since it is an electrical property combined with an electrical capacity, it is possible to measure it indirectly in a capacitive sensor. I have used capacitive sensor to measure electric relative permitivity factor of a dielectric medium can be expressed as a ration of capacity, Cx of capacitor, which space between and around the electrodes is completely filled with the medium, to capacity C0 of the same electrodes in vacuum.Ɛr= Cx/C0.I know and measured C0 value. I am facing problems with calculating Cx of capacitor, which space between and around the electrodes is completely filled with the medium.I am using method as described below.I am applying an A.C signal (125 KHz) to the capacitive sensor which is filled with some fluid, in response I am getting A.C signal with some phase difference. I am able to measure the amplitudes of sensor input, sensor output signals and their phase difference also. I am trying to make equation that will give Cx value from above known values (Vg (input), Vr (output), ᶲ (phase difference)).Any help appreciated. Please help me. Quote Link to comment Share on other sites More sharing options...
Hero999 Posted December 1, 2012 Report Share Posted December 1, 2012 I would have thought it would be easier to measure the RC time constant, rather than phase difference. It's as simple as building a relaxation oscillator with Cx + the parasitics as the capacitor being tested and measuring the frequency which will be inversely proportional to the capacitance. Quote Link to comment Share on other sites More sharing options...
