Guest Demacia Posted May 28, 2013 Report Share Posted May 28, 2013 A LED light panel is a lighting source made of flat sheet with light created by light emitting diodes. The light is spread evenly through the panel’s light distribution system. As a semiconductor, a Light Emitting Diode (LED) converts electricity into light using less energy.PL-0606-4503 PANEL LIGHT is easier to handle and since it also saves energy and lasts long, it is considered a good substitute for conventional fluorescent tubes and incandescent lamps for indoor as well as outdoor lighting; a perfect choice when it comes to cost and practicality.PL-0606-4503 can be used for under-shelf or under-cabinetry lighting, for retail displays and signage, as office lights in drop ceilings, and as decorative accents for an improved and sophisticated indoor look.Gather the following supplies, to make your own LED light panel.Step 1 – Purchase MaterialsPurchase a panel board, LED bulbs and other necessary materials. You can find them in nearby hardware stores.Step 2 – Mark the HolesMark 50 holes of 5 rows and 10 holes each in the panel. Leave a 4 inch space around the outer perimeter of the panel. Center distance between LED bulbs must be approximately 3 inches. Steps in making a smaller LED light panel follow the same principles as when making the big ones. When assembling a bigger LED light panel, you need to consider the size of the panel board and how to position the holes for the LEDs to come up with a balanced output. The previously mentioned distances may remain the same.Step 3 – Drill Holes into the PanelDrill the holes according to the marks created using a portable drill and drill bit. Do it carefully and be sure to follow the planned distance for each hole taking into account the diameter of the LED bulbs for a better fit.Step 4 – Install BulbsMake sure that the tip of the LED bulbs extrudes through the surface by pushing the lights through the back of the panel. Do it slowly and cautiously. All bulbs should fit the holes well; do not force the bulbs from the back panel since it is likely that they will break.Step 5 – Connect the LED BulbsIf all the lights are already positioned into the panel, bridge the LED bulbs in parallel connection with the use of a soldering iron and lead. Glue the plastic part of the plug to the panel to keep it from sliding around. Keep on pushing the rest of the bulbs into the holes until everything is in place. Then double check if bulbs are plugged and fitted tightly for safety.Step 6 – Tap LED Bulbs to Power SupplyTap the paralleled LED bulbs to the output of converter. The input supply of converter is Alternating Current (AC). LED bulbs use a Direct Current (DC) supply.Step 7 – Install Switch (Single Pole Single Throw Switch)Install a single pole single throw switch to the cord of the converter's input supply. The switch serves as a medium of supplying electrical current to the LED panel. Step 8 – Plug to AC SourceConnect the converter plug to AC power source. You can now enjoy your "instant" LED light panel.Also,you can buy PL-0606-4503 directly from Google. Quote Link to comment Share on other sites More sharing options...
