Guest sagi Posted January 22, 2014 Report Share Posted January 22, 2014 Hi there,I am building a circuit to measure a sensor I fabricated. The circuit is based on a simple op-amp non-inverting circuit.The sensor acts like a dynamic resistor, it changes its resistance according to the environment. The problem with the sensor is:1. That the baseline resistance is very high - tens of MOhm2. The fabrication method is not stable therefore I have variance between the baseline in each sensor I fabricate3. The change I am looking to detect are 1-90% change in resistance from the baseline.Although that, I connected the circuit to an arduino board and the results are reasonable.I have some questions to advance the circuit:1. The Vout calculation is Vout=2.5V(1+R2/Rsensor). In case I put a passive resistor in R2, when I change my sensors, I will see different response. I would like to have the ability to control R2 (potentiometer maybe) to receive better sensitivity in such case.2. I would like to connect it to a MCU (and later to wireless chip). I am not familiar with coding MCUs and found that the simple solution is Picaxe, is it?The MCU should have the ability to be connected as simple as available to wireless and/or PC.3. Low power consumption powered by thin batteries.I know its a lot but only partial help will be helpfull.Regards.Sagi Quote Link to comment Share on other sites More sharing options...
