alireza Posted February 12, 2016 Report Share Posted February 12, 2016 Hi everyoneI want to build an analog circuit that consists of 4 parts.Part1 is a simple adjustable square wavePart2 changes the duty cycle of the wave generated from Part1.Part3 shifts the phase of the wave generated from Part1.Part4 changes the duty cycle of the wave generated from Part3.I need two signals from this circuit:Signal1 from Part2Signal1 from Part4it is clear that I need four potentiometers for adjusting in all the parts.Can anyone suggest a simple circuit for the blocks? Quote Link to comment Share on other sites More sharing options...
audioguru Posted February 12, 2016 Report Share Posted February 12, 2016 A square or rectangular wave has a fundamental plus many harmonic frequencies. It is simple to change the phase of one frequency but difficult (a time delay is needed) for many frequencies. Maybe a microcontroller and somebody to program it can be used. Quote Link to comment Share on other sites More sharing options...
alireza Posted February 12, 2016 Author Report Share Posted February 12, 2016 A square or rectangular wave has a fundamental plus many harmonic frequencies. It is simple to change the phase of one frequency but difficult (a time delay is needed) for many frequencies. Maybe a microcontroller and somebody to program it can be used.Thank you audioguruusing microcontrollers is the best answer, but I want to use analog circuit. Quote Link to comment Share on other sites More sharing options...
JanHalsey Posted June 9, 2016 Report Share Posted June 9, 2016 Hi everyone..as per my experience you can easily do this with the implemented circuits. There are many boards available which can work as a function generator and the other functions you can made using any Microcontroller and the ADC and DAC circuit. Use simple components like Op-amp and oscillators. A square or rectangular wave has a fundamental plus many harmonic frequencies. It is simple to change the phase of one frequency but difficult for many frequencies. turnkey pcb assembly Quote Link to comment Share on other sites More sharing options...
