Linksprite-Yuki Posted August 24, 2016 Report Share Posted August 24, 2016 1.Create bootable TF card for pcDuino8 Uno(Ubuntu) There is no nand flash on pcDuino8 Uno, so it store the whole system on TF card. If you want to install or refresh the Ubuntu system on pcDuino8 Uno, you can just take the following steps to create the bootable TF card for pcDuino8 Uno: Pre-requisites 8G (or bigger) TF card( Speed class is recommended for Class 6 or higher) TF card reader Image for pcDuino8 Uno Windows tool: Win32DiskImager Create Plug TF Card Reader into Windows PC and open Win32DiskImager as administrator. Select the Image File that you unzip from the downloaded File Select the Device that the PC recognized Click the write button. It will say Write Successful at the end. Tips: If you only have Linux or Mac OS, how to create a bootable SD card? Only dd command is needed. <code class="lang-bash">sudo dd <span class="hljs-keyword">if</span>=<image-file>.img of=/dev/sdb bs=<span class="hljs-number">1</span>M </code> if=should be your downloaded system img file of=should be your micro-SD card. Run Plug the TF card into pcDuino8 Uno Connect 5V DC power input via Micro USB port Connect keyboard and mouse with USB hub Connect screen with HDMI cable. Power on and run Note: For the first time boot, system initialization may take some time (about 2-3 minutes ), and USB port is disabled. Please do not shutdown before system restart. Quote Link to comment Share on other sites More sharing options...
