Linksprite-Yuki Posted August 25, 2016 Report Share Posted August 25, 2016 This scratch IO shield kit is designed by https://scratch-io.wikispaces.com. The simple board is easy to solder and is then ready to use in an infinite number of projects. It contains some analog sensors onboard: light sensor, temperature sensor an angle sensor (potentiometer); some digital sensors: two push buttons. Also included, as digital output, a bi-color LED and analog power driver base on NPN transistor. There is a full range of connectors where you can plug your own sensors and actuators. This tool it is perfect for programing students, and Robotic workshops. It has been designed by teachers of the Robotics lab of Colegio San Gredos in Alcalá de Henares, Madrid, Spain. It has been developed under the OpenHardware spirit, and it is given to the community to enjoy and to be improved. This scratch_io hardware runs linked to a Scratch modification made by S4A group from citilab (free downloadable). The standard Scratch version from MIT does not support it (soon, we expect it will be supported). Let´s teach young people how to discover hardware and robotics in a friendly manner, let’s teach them how to build a better future. Parts List Analog Input Digital Input Digital Output Analog Output Oops... Servo Revisit Analog Input The following are included: 1. PCB 2. Components: 100nF C 10uF 5vol CAPAPOL D1 DOUBLE_LED Led bicolor K1 conector PCB con tornillo 3vias K2 conector PCB con tornillo 3vias P1 Tira pines simple 2,54mm (50pines) Q1 BC547 R1 5k 1/4w R2 5k 1/4w R3 5k 1/4w R4 220ohm 1/4w R5 1K 1/4w RV1 POTENCIOMETER Vertical 10k SW1 SW_PUSH_SMALL. Pulsador para PCB SW2 SW_PUSH_SMALL. Pulsador para PCB TH1 LDR U1 Lm35 Jumper 2,54… (4 units) Linker LED module RC continuous servo Quote Link to comment Share on other sites More sharing options...
