Jump to content
Electronics-Lab.com Community
Simple Server controlled LED -- MicroPython with Ameba
MENG XI
This is MicroPython project developed using Ameba RTL8722.
MicroPython is offically supported on Ameba RTL8722, so through this demo video, we will see how easy and fast it is to develop a simple server socket on Ameba, which would then control other peripheral to perform other tasks.
Here we are using a client socket code running on PC to send a 'Hello, world' string via the WiFi network, Ameba receives it and if it is indeed 'Hello, world' then it will blink the LED.
Check out the demo video down below,
Code used:
#!/usr/bin/env python3
#PC Client code
import socket
HOST = '192.168.1.152'  # The server's hostname or IP address
PORT = 80        # The port used by the server
with socket.socket(socket.AF_INET, socket.SOCK_STREAM) as s:
    s.connect((HOST, PORT))
    s.send(bytes('Hello, world','utf8'))
#Ameba Code
from machine import Pin
from wireless import WLAN
import time
import socket
wifi = WLAN(WLAN.STA)
wifi.connect("MPSSID","upyameba")
led = Pin("PB_4",Pin.OUT)
s = socket.SOCK()
port = 80
data = ' '
s.bind(port)
s.listen()
conn, addr = s.accept()
while True:
	data = conn.recv(1024)
	print(data)
	if data == b'Hello, world':
		print('turn on LED 1')
		for i in range(6):
			led.toggle()
			time.sleep_ms(200)
	if not data:
		break
Link to comment
Share on other sites
Guest
Reply to this topic...
  Only 75 emoji are allowed.
Loading...
  • Create New...
