Jump to content
Electronics-Lab.com Community
Arduino sensors modules for beginners
Shahbaz75sb
Best Arduino sensors - for beginners electronics projects
What is Sensor?
A Sensor is a device used as the primary element that measures physical value and converts it into an electrical signal. Also, we can say that the sensor is a transducer. It measures temperature, distance, light, sound, etc.
Sensors and actuators widely used in Arduino projects. These sensors come with a kit or can be purchased separately. Some of them are compatible with Arduino Uno boards and also Raspberry Pi and other electronics modules. There are lots of Arduino sensors kits available in the market.
How many types of Arduino Sensors?
There are a lot of sensors used in electronics projects, e.g. robotics cars, moving objects, flying drones, IoT(internet of things), sound and light operated, etc. Here a list of 45 in 1 electronic sensor that comes with an Arduino sensors kit, and the details of their applications.
Analog temperature Sensors
KY 013 temperature sensor
KY-013 is an analog temperature sensor module. It includes an NTC (negative temperature coefficient) thermistor. KY-13 used a bead-type thermistor, made with platinum and alloy materials. It can measure temperature from -55°C to +155°C.
Arduino sensors
Digital temperature module
Digital temperature Sensor
The digital temperature sensor contains DS18B20, a digital thermometer used for measuring the temperature of any substance.
Arduino sensors
This is a KY-028 module used with an Arduino for temperature indication purposes. NTC thermistor is the main sensor and LM393 a dual differential comparator (use two inputs, after comparison, the larger value to be sent to output).
Arduino sensors
Temperature and Humidity module
This is a DHT11 sensor for temperature and humidity measurement. The range for temperature measurement is 0 to 50 ℃. Operating voltage from 3.3 to 5V DC. The humidity measuring range is 20 to 95% RH(relative humidity).
Arduino sensors
Arduino IR sensor
IR sensor contains infrared led (transmitter) and receiver led (photodiode). It transmits infrared light, and a photodiode detects the light. We used a potentiometer for distance adjustment.
Arduino sensors
Light Dependent Resistor(LDR)
LDR works on the principal photoconductivity. It is a light sensor that is used in automatic light-operated circuits. As it gets light on its surface, it generates a few electrons.
Arduino sensors
Joystick Module
Joystick module used in robotics projects. It has an x-axis, y-axis angle, and switch option. It is very useful for robotics arms and moving objects.
Arduino sensors
Metal Touch Sensor
It is a KY- 036 metal touch sensor used as a detection sensor. If a person/human body touches this sensor tip, it will trigger and generate an output. We can use a Led as an indication or buzzer for a sound alarm. It has a MOSFET(touch sensor) and LM386(amplifier).
Arduino sensors
Sound sensor
This is a high-sensitivity, sound sensor module. It has a condenser mic and is used for sound detection.
Arduino sensors
Arduino Laser sensor
Arduino laser sensors are very useful for switching projects. It's based on the detection of motion. It also comes with a transmitter and receiver.
Arduino sensors
Arduino optical switch
Arduino optical switch used in counting projects. It also used for interrupting devices, measuring, and counting RPM purposes.
Arduino sensors
 Passive buzzer sensor
The passive sensor is used for beep/sound alarm for many electronic circuits. It is known as the KY-012 module. It required only low DC voltage(1.5 ~ 12) to activate.
                                                               Arduino sensors
Vibration sensor
A vibration sensor is a very simple module used to sense minor vibration. We can use it at the main door.
                                                               Arduino sensors
Arduino Shock sensor
This sensor is known as a knock sensor and a shock sensor. We used it for door-opening projects.
Arduino sensors
Arduino component kit
We use many electronic pieces of equipment in our routine life that may include Arduino sensors or other electronic IoT sensors and actuators. If we learn how to use them, we can understand the principle behind devices.
Link to comment
Share on other sites
Guest
Reply to this topic...
  Only 75 emoji are allowed.
Loading...
  • Create New...
