Wallystech Lily Posted January 30 Report Share Posted January 30 Unveiling the IPQ4019: Revolutionizing Long-Range Wireless Connectivity Introduction: The IPQ4019 System-on-Chip (SoC) emerges as a game-changer for Point-to-Point (PTP) and Point-to-Multipoint (PTMP) applications, presenting advanced features tailored for routers, gateways, and access points. As the industry's pioneer single-chip Wi-Fi SoC introducing Wave-2 802.11ac capabilities, the IPQ4019 boasts a highly integrated design, seamlessly blending dual-band 11ac, sophisticated Wi-Fi features, and efficient network processing. This positions it as a stellar choice for crafting high-performance, power-efficient, and cost-effective network infrastructure products. Key Specifications: Ethernet: Number of Ports: 5 CPU: Name: 4x Arm® Cortex®-A7 Processor Clock Speed: Up to 717 MHz DSP: Name: SIMD Wi-Fi: Peak Speed: Up to 1.733 Gbps Generation: Wi-Fi 4, Wi-Fi 5 Standards: 802.11n, 802.11p, 802.11ac Spectral Bands: 2.4 GHz, 5 GHz Channels: 5 MHz, 10 MHz, 40 MHz, 20 MHz, 80 MHz MIMO Configuration: 2x2 Spatial Streams: Up to 2 Encryption: AES-CCMP, AES-GCMP Security: WPA, PRNG, TKIP, WPS, WAPI, WPA2, WEP Features: TxBF, MU-MIMO, Qualcomm® Wi-Fi SON Security: Features: Secure Boot, Crypto Engine, Qualcomm® Trusted Execution Environment (TEE) Memory: Type: DDR3L RAM Density: 1 GB Interfaces: Supported Interfaces: SD/eMMC, LCD, USB 2.0, UART, PCIe 2.0, SPI, Ethernet, JTAG, I²S, RGMII, I²C, USB 3.0, S/PDIF Master I²S Modes: PCM Universal Serial Bus (USB): Specification Version: USB 3.0, USB 2.0 PCIe: Specification Version: PCIe 2.0 Package: Type: BGA Size: 18 × 18 mm Process Node and Technology: Process Node: 40 nm Wallys DR4019 - Elevating Connectivity Solutions: Featuring the industrial-grade IPQ4019/IPQ4029 chipset, Wallys DR4019 takes long-range wireless communication to new heights. Equipped with 2x2 5G high-power Radio modules and 2x2 2.4G high-power Radio modules, it supports a wide frequency range, making it an ideal choice for diverse applications. Key Features: Frequency Range: 4.940GHz to 5.825GHz (5G), 2.400GHz to 2.482GHz (2.4G) MMCX Connectors: 2 x 5G, 2 x 2.4G Bandwidth: 5MHz/10MHz/20MHz/40MHz/80MHz Wi-Fi Standards: 11ABGN/AC, Fixed Data Rate RoHS Compliance for Environmental Protection Applications: DR4019/DR4029 with DR882: Achieving tri-band functionality for optimal performance and reduced interference in industrial projects. DR4019/DR4029 with DR7915: Enhancing the performance of IPQ4019 and IPQ4029 with Wi-Fi 6E (802.11ax) chipset for reliable connectivity in various environments. Software/Hardware Customization Supported: Wallys DR40x9(IPQ4019/IPQ4029) supports open-source firmware, providing advanced customization options with OpenWRT/openwifi. Leveraging this compatibility allows users to tailor a powerful Wi-Fi solution to meet specific needs. Wallystech's Expertise: Wallystech, a distinguished research and development company specializing in Linux and WiFi protocols, brings over a decade of expertise. Focus on software/hardware modifications on Qualcomm chipset embedded board, coupled with proficiency in driver and kernel development and hardware design, ensures a comprehensive and flawless solution. For more information, contact Wallystech: Email: [email protected] Website: https://www.wallystech.com/ Quote Link to comment Share on other sites More sharing options...
