Driving a powered speaker using a microcontroller
snitishiitk
Jan 5, 2012
5
I want to drive a powered subwoofer system using the PWM of a microcontroller (Atmega32). Will that be enough or should I use an amplifier?
What input level is required?
The PWM output (if producing sine waves) will give you an RMS voltage (max) of approx the supply voltage divided by 2.8.
edit: I better explain that. I'm assuming you're wanting to use PWM and vary the duty cycle to generate the approximation of a low frequency (possibly complex) waveform. Note that you'd have to filter the output to remove the high frequency stuff, and depending on the cutoff frequency and the input impedance of your amplifier this could further reduce your available amplitude.
snitishiitk
Jan 5, 2012
5
I dont need to sound to be pleasing and clear. I just wanna produce some sort of sound. The quality doesn't really matter. So will directly connecting the microcontroller to the speaker work?
Well, you may get *some* sound. But I thought you said it was a powered subwoofer? That means it has an amp.
It may also have its own low pass filter (which is a good thing).
Do you have the specs on this device? Do you know what sort of input levels it expects?
snitishiitk
Jan 5, 2012
5
It takes the input that we normally provide from the output jack of a computer. And yes, it has an amplifier.
snitishiitk
Jan 5, 2012
5
I just have 2 questions:
1. Will it produce any sound?
2. Will it damage my microcontroller?
1) probably
2) probably not
BobK
Jan 5, 2010
7,682
PWM output from a micontroller should go through a simple RC low-pass filter, then it is suitable to put into a line-level audio input.
Bob
