pc reset/led/hd cables..
cjdelphi
Oct 26, 2011
1,166
I'm looking for a place that sells just the little black (jumper size) connectors for motherboards, so i can run a cable from the LED power out or for that matter anything (with header pins) ..
but can i find these? no .. is there a proper name for them? I have a relay with 5 header pins, so it's a choice of finding those pc type connectors (reset/power/hd/reset/etc) but all i can find are prebuilt cables with reset switch at the end or an LED at the end, i just want 10-20 connectors with cables i can feed straight into a breadboard from pc or any pcb..
but i can't find them at all, anyone seen them? i don't mind bulk buying if the price is right, i'll eventually use them.
cheers.
Something like this may be more flexible. It is probably cheaper than buying the sockets.
jackorocko
Apr 4, 2010
1,284
female headers is what I found them under on digikey. You will have to specify wire crimp style and the pitch. etc.
cjdelphi
Oct 26, 2011
1,166
thank you jack, much appreciated
Could you post a link to one of them jackorocko?
I looked up female headers and only found the female versions with pins for PCB mounting.
I couldn't find the ones which crimp on to wires (which incidentally often require a special and expensive tool)
I dodged the "name this part" question because I couldn't find them when I used that name to search for them!
Incidentally, those Chinese sources also provide the opposite, a set of connectors with pins on each end that are suited for connecting header sockets on boards to breadboards. I have a number of them, several which have already been sacrificed for small flying leads on little projects (which is why I thought of them for this)
beckya
Apr 6, 2012
7
Ebay is always tough with computer supplies. I always have better luck with craiglist
