for this setup you generally want C2 larger than C1 (that is, C1/C2>=0.1). This
proportionality is not always the case,
I think the opposite is true, i.e C1 larger than C2 (that is, C2/C1>=0.1)!!!!
Do you really mean it or you've made a mistake inadvertently?
but is typical; you increase C2 to reduce the amount of feedback.
Here I want to explain what I understand, you have to tell me if it is true or false?
The feedback signal voltage coming from emitter reaching the divider point beyween C1&C2
If this feedback signal voltage = 400mVac, and C1 = 2 C2 (C1= 20pF and C2=10pF)
Voltage is distributed in a manner opposite of resistors, i.e the large cap has the lower voltage.
now the 400mVac is applied across C2, so the voltage across C1 = 0.5*400mVac = 200mVac and the feedback signal
voltage at the base = 600mVac.
The ratio depends on what you're trying to do with the circuit, the requirements, the bandwidth, and so forth; if you decrease the ratio you increase the loaded Q.
How did you know that if I decrease the ratio I increase the loaded Q. Where did you look in the circuit?
How do you calculate it in your head and concluded that the loaded Q increases?
I'm writing this very quickly because I'm running to a meeting, but I know you have other questions. I'll try to see if I can give you more detailed answers later, but if I can't get back here I'm sure there other people on the forum here who can help
Thank you for the kind feelings
No choice but patience
thanks
