j.walter.miller
- Dec 7, 2012
- 9
- Joined
- Dec 7, 2012
- Messages
- 9
I've been reading about how to determine what type (constant current vs constant voltage) of led power supply a given led will require to operate safely.
I've found a lot of information about driving small LEDs in series and parallel, using resistors, etc.
The more I read the more I'm convinced I need some help.
I've got two different 100 watt leds:
#1: 100 watt, 20 - 22v maximum forward voltage, 3500mA maximum forward current
#2: 100 watt, 34v maximum forward voltage, 3500mA maximum forward current
I'd like to get some advice on buying a couple of MeanWell power supplies.
There are several types offered:
Type A: Operates in constant voltage or constant current mode. A-type also has potentiometer for output voltage and output current adjustment.
Type B: Dimmer version.
My goal is to operate these LEDs at about 80% of their maximum threshold. My plan is to buy two power supplies, one for each led.
Can you help me pick out a power supply for each of these leds? I'm learning but want to make sure the choices I make won't burn up the leds.
Type A: http://www.trcelectronics.com/Meanwell/power-supply-hlg-h.shtml#100w
Type B: http://www.trcelectronics.com/Meanwell/power-supply-hlg-b.shtml#100w
I'd like to be able to dim these leds using a potentiometer.
