Electro132
- Feb 12, 2013
- 261
- Joined
- Feb 12, 2013
- Messages
- 261
Hi,
Could resonance be picked up by a receiver? and if so by what?
Hi,
Resonance better be able to be picked up by a receiver, or else I'm not sure how you are viewing this web page on your computer since your computer modem uses tuned circuits as well as the internet network uses tuned circuits.
Perhaps are you asking something less literal?
I need some assistance in converting 13 - 60 pulses per second, 7 - 13 pulses per second, 4 - 7 pulses and 1 - 4 pulses per second to Hz.
Convert to what? Pulses per second is the same as Hertz (Hz). Do you really mean convert?I need some assistance in converting 13 - 60 pulses
That depends entirely on the circuit. There are many types of resonant circuit and each can be tuned in one or more ways.I also need to know how does resonant frequency change on a tuned circuit
This sounds more like you want to build a frequency generator for low frequencies, do you?what components would i need to achieve these pulses/hz
Resonance is not going to have much to do with pulses at the rates you are talking about. Yes, you could build resonant circuits for those low frequencies but it would take them minutes to settle when a signal was received.
If you want help, stop asking questions that don't make any sense and tell us what it is you are trying to do.
Bob
Harald Kapp; said:You need to be much more specific if you want to get useable answers. Tell us exactly what you need:
- your application. This is the most important part helping us understand what you want to do. Sometimes what you want to do and how you want to it is not the best way to achieve the final goal.
Also:
- voltage levels,
- current levels
- frequency range(s)
- signal form(s) (sinusoidal, rectangular, triangular...)
- anything else that comes to mind (e.g. does the generator have to run synchronously to another generator, do you need a trigger siganl etc.)
(1)I need some assistance in converting 13 - 60 pulses per second, 7 - 13 pulses per second, 4 - 7 pulses and 1 - 4 pulses per second to Hz.
(2)I also need to know how does resonant frequency change on a tuned circuit (what components would i need to achieve these pulses/hz) by providing feedback onto it and changing the resistor.
(3)I'm guessing the end part would be the sine, triangle, sawtooth waves that get emitted by light?![]()
(1)
13 pulses/second =13 cycles/second =13 Hz
(2)
The resonant frequency in a circuit consisting of a capacitor and an inductor (LC circuit) is:
f = 1 / ( 2 pi *(square root of (L*C)) )
, where L is the inductance in henries, C is the capacitance in farads, and f is the frequency in cycles per second (or otherwise known as hertz).
The resonant frequency in a circuit consisting of a capacitor and a resistor (RC circuit) is:
f = 1 / ( 2 pi*R*C )
, where R is the resistance in ohms, C is the capacitance in farads, and f is the frequency in cycles per second (or otherwise known as hertz).
Once again you have not told us what you want to do. You have told us what you think you need (and your statements here are confusing at best). Tell us what you are trying to achieve, not that you need an oscillator in the range of 100KHz to 100GHz (which you surely will not be able to build). What are you going to do with this oscillator?
Bob
I want to build a Resonator which can be used for my experiment in examining the power of vibrating waves.
It should have an Audio, RF and LFO altogether and have the ability to be powered by an inverter which can provide power to a supercapacitor and thus the supercap will then send power to the rest of the circuit.
Finally the tone will be used by a linear pot for the audio, RF and LFO to be connected to it whilst having Log Pots to control volume. This should all come out on either a sine wave or non sine wave which ever is more effective.Was thinking a Phase shift Oscillator was better for this but having difficulty building the schematics for it. Any help is appreciated.
Just a reminder i will use it in an experiment where i examine the power of vibration through several walls of glass, concrete and other materials.
Cheers
(1)
Now what is it that you wanted to build, after I just explained to you what you can do with a resistor in a circuit to created a tuned circuit?
You want to do something with an inverter providing power for the tuned circuit?
NO. No you don't. An inverter converts DC to 60Hz AC. If you use an inverter the frequency of your circuit is 60Hz.
P.S.:
(3) Radio frequency used to broadcast radio waves is not in the visible spectrum, but the visible spectrum is part of the electromagnetic spectrum. Go to the Wiki link I posted for electromagnetic spectrum.
linear pot = a variable resistor ... it isnt going to move between any set of frequencies
Dave
I beg to differ that a pot in a circuit with a capacitor can indeed create a tuned circuit, at least that appears to be what happens with my guitar that has RF interference problems when I turn the tone control knobs (linear pot) it doesn't do anything but when I turn the volume knob (log pot) I can tune to different AM stations. At one volume level there is a news station at 780KHZ and at the opposite volume level there is a gospel music station at I think around 1200KHZ (that is what I found on the internet for gospel music stations nearby me). The news station transmitter is 15 miles away from my house and the gospel music station transmitter is 10 miles away from my house. Also I was using the pickup selector switch at the same time to create taps to the total number of coils in the circuit.
So a linear pot can not create a tuned circuit but a log pot can create a tuned circuit? Or at least if appears that a log pot with guitar pickups can create a crude tuned circuit for AM stations transmitting at thousands of watts only a few miles away. I think the frequency equation is logarithmic/exponential behavior, so that is why a log pot will work but a linear pot will synthesize such low frequencies that it doesn't do anything?
Or is it likely that the log pot doing anything was just dumb luck and it only worked because I was using the pickup selector switch at the same time?
what do you really mean ?
we are all trying desparately to help you, but your descriptions are making it really difficult
Dave
