Elecbegginner
- Mar 24, 2013
- 103
- Joined
- Mar 24, 2013
- Messages
- 103
The problem is that the motor that i checked the previous card with is working fine , but on this card i get very weird output voltages , i am suspecting the Thyristor is not working as it should be .I made abig boob when I suggested limiting current with a car headlight bulb. I thought you were running at 12V
To check the motor, put a filament bulb (mains) in series to limit the current.
To check the thyristor, use a light bulb as a load.
It looks as if you have a dead motor. What sort is it? Does it contain brushes running on a commutator?
Is there any connection across the input terminals? If not, then turn the motor by hand and see if there is an intermittent connection.
The thyristor works by chopping the sine wave so that the average power is reduced. The output voltage measured will depend on the way the meter works.
And what is more weird is that the motor does not turn even with for example 189 volts at output .
