Hi all,
Just a quick question for you: is it at all possible to use a capacitor voltage divider with DC voltages? I know, somewhat stupid question given that caps tend to remove DC offset and thus the output would always be pretty much 0V, but I am wondering if there is some kind of known circuitry that allows DC voltages to be divided by such a capacitor.
For those wondering why I want to do this, or why I can't use a simple resistor voltage divider: I want to build a theremin controller for an analogue synth. Theremins work by using your body and the metal rod as a capacitor.
The best I've got is I could run a signal, like a sine wave, to the first cap in a series of two, use the divider as an attenuator, then use a setup of diodes and regulators on the output (between the caps) to end up with positive and negative (or just positive, I can invert the signal) DC outputs. I have no idea if that would even work, let alone how well it would work.
What I really want is the ability to use a theremin-like setup as a way to control an output capable of voltage sweeps from +5V to -5V. Any advice is appreciated.
